Em-trak Announces New B900 Series of AIS Transponders
Postby jimh » Thu Mar 19, 2020 9:07 am
Em-trak, the house brand of SRT Marine Systems Group, who are the principal developers of AIS devices and the OEM for many private-label branded devices, have announced a new B900 series of AIS Class-B devices.
Fig. 1. Front view of em-trak B900 enclosure.
Common to all models are these features:
  • internal GNSS receiver and antenna, 72-channels, capable of receiving GPS, GALILEO, GLONASS, and BEIDOU;
  • water and weather proof enclosure to IPx6 / IPx7;
  • two NMEA-0183 ports;
  • NMEA-2000 port;
  • small size and light weight;
  • very low power consumption;
  • TNC connector for external GNSS antenna if needed;
  • FlexFit mounting bracket;
  • USB connector for interface to computer terminal, and
  • silent mode switch for receive-only operation.
There are two branches of the B900 series: 2-Watt Class-B Carrier Sense devices, and 5-Watt Class-B Self Organizing devices. In each branch there are: a base model; a model that adds WiFi, Bluetooth (BT), and a voyage data logger; a model that adds an internal antenna splitter; and a model that adds WiFi, Bluetooth, a voyage data logger, and internal antenna splitter. Here are the model designators and MSRP in US dollars:
2-Watt Carrier Sense CSTDMA
B921 base model = $499
B922 + WiFi/BT + voyage data logger = $699
B923 + Antenna Splitter = $649
B924 + WiFi/BT + Antenna Splitter + voyage data logger = $899
5-Watt Self Organizing SOTDMA
B951 base model = $599
B952 + WiFi/BT + voyage data logger = $799
B953 + Antenna Splitter = $749
B954 + WiFi/BT + Antenna Splitter +voyage data logger = $999
The GNSS receiver can receive any two GNSS systems simultaneously, and three systems can be received simultaneously if two are GPS and GALILEO. The GNSS receiver sensitivity is said to be very good, and em-trak does not expect that an external antenna will be needed if the unit is mounted on deck or under a fiberglass deck, or inside a helm console on an open boat.
The optional internal antenna splitter allows the AIS transponder and a VHF Marine Band radio to share a common antenna. The shared antenna must be an antenna with a wide VSWR bandwidth that can work at both 156-MHz and 162-MHz.
Both NMEA-0183 ports have TALKER and LISTENER balanced pairs. The primary port uses the recommended NMEA wire insulation colors to aid in identification of the signals. The baud rate is 38,400-bps. The second port uses an alternate set of wire insulation colors to distinguish it from the primary port, and it operates at 4,800-bps. The NMEA-2000 port is provided on the standard DeviceNET Micro connector.
The average power consumption of models without the optional antenna splitter ((B921/B922/B951/B952) is only 0.17-Ampere or 1.6-Watts at 12-Volts. The models with the antenna splitter (B923/B924/B953/B954) consume slightly more average power, 0.28-Ampere or 2.1-Watts at 12-Volts.
There is a 12-pole connector for attaching the wiring harness to the device for power, the two NMEA-0183 ports, and the Silent Mode switch. The wiring harness is 2-meters long.
Models with the optional antenna splitter add a second SO-239 connector. A 1-meter cable for connecting to a VHF Marine Band radio is also supplied.
The configuration of the B900 series is accomplished with a software application, proAIS2. Versions of proAIS2 are available for both WindowsOS and MacOS. A computer-to-B900 connection can be made using a USB port and a micro-USB cable. The required cable is not supplied but is widely available. In the USA, the B900 devices will be delivered from the dealer with pre-configured settings for the MMSI and other data (such as CALLSIGN, VESSEL NAME, and dimensions of the offset of the GNSS sensor in the hull).
The models with WiFi and Bluetooth can connect to a smartphone using the CONNECT-AIS application, available for Google smartphones and Apple iOS devices. This application also be used for configuration of the B900 device.
Don McIntyre - MI
Re: Em-trak Announces New B900 Series of AIS Transponders
Postby Don McIntyre - MI » Mon Mar 23, 2020 6:08 pm
Jim--Which one do you recommend?
Postby jimh » Fri Mar 27, 2020 11:18 am
I'd likely buy the least expensive one for my small boat. I have had great experience with em-trak products. I wouldn't get the antenna splitter because I would consider having a second antenna for the AIS to be really an in-place spare antenna for my VHF Marine Band radio. I wouldn't get the WiFi/Bluetooth because I really don't use a smartphone or tablet on the boat. I do like the data recorder option that comes with the WiFi/Bluetooth models. I might opt for the 5-watt model, considering the modest $100 increase in price from the 2-Watt model.
