1989 Montauk Rub Rails
enggass
Postby enggass » Mon Oct 09, 2017 5:55 pm
Is it common to see cracking next to rubber on 28 yo rub rails? Is this an easy fix? What is it a sign of?
Re: 1989 Montauk Rub Rails
Postby jimh » Mon Oct 09, 2017 7:10 pm
Rub rails are not made of rubber.
enggass
Postby enggass » Mon Oct 09, 2017 7:35 pm
Ok. Next to the black material that I thought was rubber. Is it common to se this after 28yrs?
enggass
Postby enggass » Mon Oct 09, 2017 7:43 pm
Actually is rubber. The black part. I pulled this from the install manual of the OEM part.
“3 components that make up the rub rail - rigid receiver (hard plastic), a small flexible rubber “L” shaped trim, and a flexible rubber “insert
