Replacement Karavan Trailer Fenders 190 Montauk
Whalerdog
Postby Whalerdog » Mon Mar 05, 2018 2:54 pm
I see in the literature and owner's manual I received with the [Boston Whaler 190 MONTAUK] boat the part numbers [for replacement fenders for the Karavan trailer] are
310-02070 RH
310-020-69 LH
The trailer is not near me. Are the tires 14-inch or 15-inch?
A drawing showing the trailer just says fender and rim [without] sizes.
I called dealer for Karavan and they seem lost with [those] part numbers.
I see some from Great Lakes Skipper which seem similar. They offer no part number just that they are from a Bayliner trailer and 37-inch-long.
Googled name and part numbers with no success.
Any help us appreciated.
Can't tell length of my fender as some of it is gone. Width is about 9.5-inches. Height is 11-feet [inches], and length may be 37-inches, but some is missing.
Dutchman
Re: Replacement Karavan Trailer Fenders 190 Montauk
Postby Dutchman » Mon Mar 05, 2018 3:22 pm
Have you tried Karavan direct 920-928-6200 Option 3
EJO
Re: Karavan trailer fenders 19 Montauk replacement?
Postby Jefecinco » Mon Mar 05, 2018 7:19 pm
Fifteen inch on the Karavan that came under our 190 Montauk.
Wweez
Postby Wweez » Mon Mar 05, 2018 8:26 pm
Karavan has been most helpful. You may need your vin which is on your registration papers.
Whalerdog
Re: Ordering From Karavan
Postby Whalerdog » Tue Mar 06, 2018 2:16 pm
Ordering from Karavan. Each fender$24. [KARAVAN] changed the way [the fender] mounts. No screws from bottom. Now carriage bolts 3.xx.
[KARAVAN] said fenders are 40-inch long. When I get to boat I'll measure the fender that is intact.
Also check if I need a [lamp] or grommets.
Part number I gave was whole assembly.
Thanks all.
Whalerdog
Postby Whalerdog » Thu May 10, 2018 7:36 pm
Swapped them out. Mounting tabs on trailer were rusted. Wire wheeled 99-percent of the rust off the brackets. Use rust converter, spray galvanized, and then Por15 undercoating. Two new lights and it's done.
Dutchman
Postby Dutchman » Fri May 18, 2018 9:09 am
Thanks for the update.
I cracked one of mine (I'm to heavy for that plastic) and must replace it. good to know Karavan is helpful.
EJO
Whalerdog
Postby Whalerdog » Sat May 19, 2018 6:34 am
No clue what you weigh but I think fenders only crack after aging from UV damage. I would bet 300 lb. would be safe. They bolt on in existing holes now. New LED light and rubber gasket was cheap too just under 4 bucks.
