2016 Montauk 210 Locker: Six Questions
Montauk1492
Postby Montauk1492 » Tue Oct 23, 2018 11:09 am
I am the happy new owner of a 2016 Montauk 210.
In the anchor locker water easily enters from the top, and also from the open drain when I go far forward.
Q1: Is the anchor locker continuously wet and has mildew?
Q2: When its drain is closed will the fish locker stay dry enough to stow hand tools?
Q3: Does water leak into the console locker?
Q4: The locker below helmsman's seat does not seem dry; will a gasket at top lid solve the problem?
Q5: If so what gasket material?
Q6: Are the aft battery lockers designed to stay very wet?
Re: stowing tools
Postby jimh » Tue Oct 23, 2018 12:03 pm
Montauk1492 wrote:Q2:...will the [live well] stay dry enough to stow hand tools?
I suggest you do not anticipate that hand tools will remain dry in any sort of below deck locker. I use inexpensive water-tight boxes, often sold as utility boxes for anglers or ammo boxes for shooters, to hold all the stuff I stow in a live well at below deck level on my Boston Whaler boat. For example, see
http://www.planomolding.com/emergency-supply-box-with-removable-shelf
I think they also make these in a white color. They work well to keep out water and maintain tools and expensive spare parts in a dry environment.
You can find similar Plano boxes for as little as $6 each. See
https://www.walnutcreekoutdoors.com/plano-field-ammo-box-1312-50/
https://www.globalindustrial.com/p/storage/bins-totes-containers/lockable-storage-box-trunk/plano-water-resistant-storage-box-11-5-8-l-x-5-1-8-w-x-7-1-8-h-green
Ridge Runner
Re: 2016 Montauk 210 Locker: Six Questions
Postby Ridge Runner » Sat Oct 27, 2018 8:23 pm
I have a 2016 210 Montauk; my answers are below;
My anchor locker stays fairly dry, I do wash down my archor in the locker and leave the cover open until dry. Any water that enters the front opening for the rode flows down to the drain. I do have the locker lined with Dri-Dek that I customized to fit the locker. I also lined the fish locker floor and the floor in the center console. https://www.amazon.com/Dri-Dek-1x1-Inte ... VS6N8?th=1
As Jim stated I would not store any hand tools in an open environment. I do store towels, fenders and cleaning supplies in the fish locker, so far it has been water tight for me.
My center console locker stays dry
Q4: The locker below helmsman's seat does not seem dry; will a gasket at top lid lid solve the problem?
I don't have this configuration - I have have the livewell.
This would be my biggest frustration point with my 210 Montauk - water getting into the battery lockers and in the battery trays. Mold and algae are always growing on the interior platforms that the batteries sit on and it's a pain to clean. I drilled holes in my battery trays so the water would drain out and the batteries wouldn't be sitting in water. If anyone has a solution that solves the water sitting on the battery platforms problem please let me know!
Member since 2005
