VERADO Flushing Port Left Open
WayneR
Postby WayneR » Mon Jul 29, 2019 8:21 am
I recently purchased a new Vantage with Mercury 250-HP VERSDO FOURSTROKE outboards. They have A flushing system that connects to a garden hose to flush the saltwater out of the engine.
After the last flushing, we forgot to cap that flushing port and just pushed it back inside the cowling. I noticed it after a cruise, and I am now concerned that we basically hosed down the VERADO with saltwater.
What should be done at this point?
Has serious damage been done to the engines?
Thank you
Re: VERADO Flushing Port Left Open
Postby Jefecinco » Mon Jul 29, 2019 9:30 am
Remove the engine cowling and rinse the engine well with fresh water. You may need to remove the chaps but that is unlikely. Give it a good dousing with "Salt Away" following the instructions provided. Do not use a power washer and generally avoid high pressure. If the "overheat" alarm failed to sound I doubt the engine was damaged as it was manufactured for use in salt water and the water pump provides a high flow rate.
I've experienced leaking of the flushing system hose connector when tightly capped and inside the cowling. Although the cap has a hose fitting o-ring gasket it continued to leak when tightened. I discovered that a five cent coin, aka nickel, placed in the cap prevents leaking.
I read about the problem and a long term solution in the Verado Club's library, http://www.veradoclub.com which is provided for those who choose not to subscribe. You can also ask a limited number of questions on the site forum without subscribing. The library is an excellent resource for Verado owners.
