E-TEC 90 Color: Graphite or White
kwik_wurk
Postby kwik_wurk » Wed Apr 27, 2016 4:53 pm
I am close to purchasing a new E-TEC 90. I have never liked white engines, as they always get scum on them when you tilt them up. Graphite or White?
Marc-B
Re: E-TEC 90 Color: Graphite or White?
Postby Marc-B » Wed Apr 27, 2016 10:06 pm
Just got E-TEC 90 in graphite--looks good
macfam
Postby macfam » Wed Apr 27, 2016 10:17 pm
[Choose] graphite.
Postby Jefecinco » Thu Apr 28, 2016 10:19 am
White is clearly a better color with a white hull. For tan hull a little less so. It seems that white is a preferred color with white hulls along the central southern coast.
The major advantage is that white makes it far easier to know when the engine needs a good cleaning. It is also easier on the hands when touching the cowling in the summer sunshine.;=)
brill
Postby brill » Thu Apr 28, 2016 10:42 am
It depends on the hull. If it's an older model with blue interior, I would go with white. My opinion is that the white engines look better on the older hulls since they look more like the older OMC engines. There are advantages and disadvantages to each cowling color. The graphite will be less likely to show scum as well as grease stains. It sounds like you have a preference for the graphite, so go with it.
Einar
Postby Einar » Thu Apr 28, 2016 11:04 am
I just had a white E-TEC 90 hung on my 1981 Montauk. It looks just like the Johnson it is replacing.--Al
Postby jimh » Thu Apr 28, 2016 12:02 pm
If you do not like white engine cowlings, I think your choice should be the non-white cowling, unless you dislike graphic more than you dislike white.
Bala-Jig SF
Postby Bala-Jig SF » Thu Apr 28, 2016 11:42 pm
I went with graphite. the only downside is it shows off the water spots.
kwik_wurk
Postby kwik_wurk » Sat Apr 30, 2016 2:36 pm
I went with white, I actually don't mind the color. It's more I hope I don't have to keep a pile of rags on the boat to keep the E-TEC looking clean. --- It will live on a buoy and dock so, won't get washed down every trip.
4whaler
Postby 4whaler » Mon May 02, 2016 5:08 pm
White. That is what I have on my 15' GLS II commercial lay up which is white. Have a red prop... really looks good.
