For Sale: 1989 50 hp Yamaha 2-stroke outboard. 15-in shaft. Freshwater use only. This package includes a new old stock Yamaha 703 Pull to open 10 pin OEM remote control box (hard to find) and new paired Yamaha Pro tachometer.
VRO pump has been removed, intentionally, and now requires gas to be pre-mixed.
The motor has been completely gone through by local outboard mechanic with approximately $750 in parts and labor spent. (Receipt with details can be provided)
Four holes were drilled in the cavitation plate for a dol-fin (prior owner) but have since been removed. Holes remain and can be seen in the picture.
There are two small cosmetic flaws There is a small notch/filing in the U clamp that wraps over the transom. It is adjacent to the Yamaha model number plate. There is also some small nicks on the rubber gasket which seals the shroud onto the motor. See picture attached.
My outboard mechanic had a separate Yamaha long shaft salvage for which he provided future backup parts. Box of spare parts which includes things like spare engine block, electronics, etc. (Easily worth a few hundred dollars)
Weight is specified at 191 lb
This model does not have power trim and tilt.
Motor is still mounted to the boat and operable for inspection.
Located in Denver, Colorado
Price is $2950
FS: 1989 50 hp Yamaha 2-stroke outboard. 15-in shaft. Freshwater use only.
- 1989 Yamah Outboard.jpg (13.78 KiB) Viewed 3193 times
