Wanted to buy: a clean used [170 was 150] Montauk , preferably one that’s already dressed up for fishing. I live in southern Ohio and the boat will reside in Lantana, Fl. Call or text 440-759-5907. Thanks
Note: I originally posted that I wanted a 15’, but after visiting the local Whaler dealer I discovered that a 15’ is very cramped and that the 17’ would be more appropriate.
WTB: Used 170 Montauk
Re: WTB: Used 150 Montauk
Are you in FL now Chris? There are many 150's on craigslist here. I could probably find at least 5 in Tampa area only. I found 2 150 Montauks.
Re: WTB: Used 170 Montauk
Yep, I’m in Lantana and actually just started browsing Craigslist. Thanks for the tip.
Try Boat trader and iboats as well as other online sites. Many people upgrade to a larger boat from the 17' so they are usually not scarce to find used. Depending on what you are looking to spend and if you have any size restrictions, look for the 16' Dauntless as well.
Thanks, I appreciate your help
