1990 15 SS LTD 1989 70 Mercury for sale $4500 in Florida
Joe 15 SS LTD
Postby Joe 15 SS LTD » Tue Mar 22, 2016 10:12 pm
For sale: 1990 15 Super Sport Limited (SSL), with 1989 Mercury 70, $4,500 [in Florida]
Not advertised anywhere else; pretty firm on price; not in a hurry to sell but would like my garage back.
I am original owner. I have not used [this 1990 15 SS LTD 1989 70 Mercury] in about 20 months, and then not for 18 months before that.
The boat ran fine before it was parked in my garage, I did run the gas out of the carburetors and fogged the engine. The engine should have impeller replaced--it has been more than 6 years since it was replaced. The lower unit gear oil needs to be changed. The fuel and oil lines should be replaced; I replaced oil lines about 15 years ago. Should replace fuel lines on tanks.
Every two months I spin the engine flywheel one-half-revolution by hand using a big wrench.
Engine is mounted one hole up; it has a Dole-fin mounted.
The 15 SSL has a pony motor bracket and about a 40-lbs-thrust Great White trolling motor. The pony motor bracket is off; I took it off to be powder coated an dnever put it back on,, I have the hardware to reinstall if I can find it
Battery dead
depth finder
Speedometer
Tachometer
Bilge pump
Bimini top red in color
Stainless steel 3 blade prop,not sure of pitch 17"or 19" will check ran about 42 mph by it's speedometer with my self the wife and 18 gallons fuel in 3 each six gallon tanks and 1ea 3 gallon tank, all fit under rear deck with battery. Sometimes would keep 2 empty tanks closest to stern and tanks with fuel in front of empty tanks for trim still under rear deck
Ski pylon slightly bent
Whaler bag for paperwork from original sale.
2002 I think Performance trailer used approximately 25 times and rinsed off afterwards, tires are I assume 2002 new with trailer, has spare tire also old, should probably be replaced due to age not wear
It has a set of not expensive skis and a Big Berths tube along with ski vest and regular life jackets
It has a spare aluminum prop, slightly dinged from storage not use.
I think the oil level alarm has been disconnected due to a malfunction, I always checked oil at each trip and kept it fairly full for each use
Has stern light pole but connector broke, I used waterproof twist on connector for the 2 wires, not sure where they are now, not much for night boating.
Added Stainless grab rails around wind screen for protection of the screens and to hold on to
I have pictures on Whaler Central under Joe 15 SS LTD POSTED in 2005 in personal pages, I used the boat maybe 10 times since then, got into kayaking in 2003
You can contact me thru private message from Continuouswave
Last edited by Joe 15 SS LTD on Mon Mar 28, 2016 8:33 pm, edited 5 times in total.
grizzly
Re: 1990 15 SS LTD 1989 70 Mercury for sale $4500.00
Postby grizzly » Wed Mar 23, 2016 12:01 am
[Could not use PM because he has no posting history]
How can I contact you?
Joe 15 SS LTD
Postby Joe 15 SS LTD » Wed Mar 23, 2016 8:50 am
Grizzly
Sent you a message
Joeandrekus396@msn.com is my contact I am in Seffner Fl near Tampa
Joe 15 SS LTD
Postby Joe 15 SS LTD » Thu Mar 24, 2016 11:27 am
Generic Boat cover included
Anchor and line included
update to big bertha tube still holds air but handles have UV rot and are not good
Whaler bow cushion included, I never used it, I think I bought it from someone on this site quite a while ago
I took some pictures today and will email them to those who ask
donb43402
Postby donb43402 » Sat Aug 25, 2018 10:18 am
hey joe, don butler here. i found the info on the boat but couldnt locate any pictures. you can send them via email if thats convenient. thanks
Joe 15 SS LTD
Postby Joe 15 SS LTD » Sat Aug 25, 2018 10:24 am
Pictures to be sent.
