FS: 1989 OUTRAGE 22 $32,000 in Florida
larimore
Postby larimore » Thu Nov 30, 2023 10:03 am
For-sale: a 1989 OUTRAGE 22 with 1999 Yamaha 225-HP engine on a trailer for $32,000 in Florida.
CONTACT: Purchase@JoyceAndMichael.US
The 1989 OUTRAGE 22 boat has been trailered and covered in Florida all its life, and has been used maybe ten times a year since 2000. The rub rail was replaced in 2022. The teak and fiberglass are in good shape. The fuel tank has green zinc chromate coating, and it shows no signs of significant corrosion. The hull is in excellent condition, no soft spots and no significant dings. The boat has never been kept in the water, and it has always been covered.
The canvas was custom made using Sunbrella fabric and stainless steel frames by a fantastic canvas guy. The dodger area has two large cushions that span the width of the hull to make a large bed. The entire bed is easily removable; I leave the front cushion in place for a comfortable lounging area.
The 1999 Yamaha 225-HP two-stroke-power-cycle Saltwater Series Ox66 engine has extremely low hours, and it starts and runs perfectly. The engine has been started and fresh-water flushed monthly--more often than it gets used. The 1999 engine is the from the last model year Yamaha made a 225-HP two-stroke-power-cycle engine. I bought his engine because of that.
The 1999 Yamaha 225-HP two-stroke-power-cycle Saltwater Series Ox66 engine was used in saltwater around Miami, Florida. There is minimal corrosion on the engine, and it is periodically misted with WD40 under the cowling.
Summer is my high-use time, but in 2023 I used the boat only about five times to travel to my usual spot 45 minutes each way. When not in Summer there was less use of the boat.
The float-on trailer was custom fabricated to fit the OUTRAGE 22, and it has a folding tongue. The trailer is in perfect working condition. The axles, tires and wheels were replaced in 2017 with premium axles, tires, and wheels. Tail lights are LED and are submersible. The trailer was generally used only to tow the boat three miles from my house to a launch ramp.
OTHER EQUIPMENT
  • custom taller plexiglass windshield
  • large custom leaning post and cabinet
  • custom canvas for overnighting
  • 15-gallon freshwater shower
  • bow dodger with no-see-um screening
  • two-part removable bed that sleeps two
  • SeaStar Hydraulic steering
  • Bennett hydraulic trim tabs
  • Garmin 942xs Chartplotter
  • Standard Horizon GX1700W radio
  • Magellan fish-finder
  • remote spotlight
  • Fortress anchor
  • 25-lbs CQR anchor
  • Magma Grill
  • 1500-Watt inverter
  • audio entertainment system
  • deep cycle battery
  • starting battery
  • custom enclosure for oil reservoir tank and starting battery
  • excellent four-step boarding swim ladder
TOW CAR ALSO AVAILABLE
A 2004 Crown Victoria LX Sport with 110,000-miles and in good condition is available with the boat for an additional $2,000 ($34,000 for boat and car.)
Additional Pictures can be seen at http://www.boattrader.com/boat/1989-bos ... 2-9153972/ - Or by request
Whaler 1.jpg (96.12 KiB) Viewed 1446 times
Whaler 2.jpg (96.84 KiB) Viewed 1446 times
Whaler 3.jpg (84.91 KiB) Viewed 1446 times
Alkar
Re: FS: 1989 OUTRAGE 22 - 1999 YAMAHA 225
Postby Alkar » Sun Dec 17, 2023 6:18 pm
[Contact the seller directly to obtain further information about the boat he is offering for sale. Note that the original post is extremely comprehensive in listing details.--Moderator]
larimore
Postby larimore » Fri Mar 29, 2024 9:03 pm
Boat is still for sale $30,000.
