Greetings to all and thank you for all the valuable information you have provided me thus far while I silently surfed the forum over the last four years. I own a 2007 210 Outrage with the leaning post livewell option that I'm contemplating removing for a barebones leaning post/seat. My purpose is to gain a more open area as I don't use the live well, and prefer to troll using artificial lures.
I would appreciate your input in regards to the problems that I will likely have to address: the deck openings, the through hull fittings leading to the live pump, etc. Thanks!
210 Outrage Leaning Post Livewell Modification
Re: 210 Outrage Leaning Post Livewell Modification
Where are you located?
Duane
2016 World Cat 230DC
1997 Outrage 18, Yamaha 125
1983 15 SS, Honda 50
1980 42 Post
1983 34 Luhrs 340 SF
Duane
1980 42 Post
Here are some parts diagrams that may be of help to you. They are from http://www.whalerparts.com for the 2007 Outrage 210.
Livewell/ Sub assemblies:
http://whalerparts.com/Diagrams/2007/210%20Outrage/09421210ORSHT1-4.pdf
Plumbing:
http://whalerparts.com/Diagrams/2007/210%20Outrage/06103210ORSHT1-3.pdf
Drain:
http://whalerparts.com/Diagrams/2007/210%20Outrage/06601210ORSHT1.pdf
Plumbing:
Drain:
Phil thanks for the diagrams. I see the piping comes thru a single access port, which I imagine I can fit with a tank cover. Then the screw holes would need patching - Can anyone say if that would require fiberglass or simply caulk?
I'm in Fort Lauderdale.
Ed
Ed
