25 Outrage – Drain for Fuel Tank Area
Posted: Mon Jul 18, 2016 9:40 am
Hello to everyone. I am getting close to a very delayed start to this year’s boating season. In June, when I launched my 25 Outrage the “water in the fuel” alarm went off immediately. After some investigating it was clear that the fuel was contaminated. My Boston Whaler is a 1985 with the original fuel tank, so I knew this day was coming. I have been working on replacing the fuel tank for the last six weeks. The old tank had several holes on top and pitting all over. The new tank should arrive at the end of this week.
After reading several previous posts about fuel tank replacement, I want to put a drain at the bottom of the fuel tank cavity that goes to the aft bilge compartment. It looks like this would be relatively simple to install. However, after reading posts on this subject I haven’t been able to find any pictures or the type of drain being used. Any advice on this would be appreciated. I imagine I’ll have to cover it with a strip of plastic over the top once the tank is in so the new foam doesn’t block the drain.
Ideally, I would inspect periodically and drain when needed. I would also store it with the plug out during the winter when it’s on my trailer. I will also make sure that the deck is caulked properly and I make sure the fuel fill area is as sealed as possible.
Thanks for your help, I am shooting for an August 1st re-launch!
Jay
Jay
