17 Montauk Hand Rails
ktval
Postby ktval » Thu Aug 24, 2017 5:52 pm
Hi all, I have a 1995 Montauk that i Just remover the bow rail on. When i remover it the top supports seam to not be screwed into anything. They were just silicone in :-(. Now I just have a bunch of holes about the size of an pencil eraser. Is there suppose to be anything in the holes?? If so what and where can i get replacements?? Thank You
1995 Montauk 1995 Merc 90. Port Jefferson and Greenport NY
Re: 17 Montauk Hand Rails
Postby Phil T » Fri Aug 25, 2017 8:24 am
If you will reinstall the rail or sell the boat in the next 5 years, reinstall the screws with a good bead of polysulfide based sealant (not adhesive). Otherwise get some color matched patch kit from spectrum and seal the holes.
http://www.spectrumcolor.com/ProductDesc.aspx?code=F552208K&type=4&eq=&desc=BOSTON-WHALER-WHITE-94-96&key=it
ktval
Postby ktval » Sat Aug 26, 2017 8:44 am
Thank you for the response. I find it hard to believe that there is not suppose to be something in these holes. They are all about the same size and all exactly the same screws cam out, however they were not screwed into anything.
