Refinish Mahogany
PatSea
Refinish Mahogany
Postby PatSea » Sat Mar 24, 2018 11:39 am
I have a 1972 Sport 13. I am refinishing the helm as the varnish is old and has a few cracks. I want to protect it from damage. I understand I need to sand it down to bare wood.
Do I need to stain the mahogany again before applying the Z-Spar varnish?
My concern is matching the other wood pieces as I am not planning to refinish all the wood at this time. If I need to stain it what do you suggest I use to match what is already there?
PatSea
Re: Refinish Mahogany
Postby PatSea » Sun Mar 25, 2018 9:15 am
After doing more digging through the old CW forum I found several threads on refinishing mahogany with a ton of good information. I will not be staining the wood. And I like the idea of using SS fender washers under the trim washers to avoid the trim washers cracking into my new varnish. I do have a little dark mildew around several of the screw holes which I will try to bleach out before refinishing.
Bigbear
Postby Bigbear » Sun Mar 25, 2018 11:37 am
I used to also use fender washers but found flanged finish washers which appear better and reduce the number of pieces.
PatSea
Postby PatSea » Sun Mar 25, 2018 12:00 pm
Thanks BigBear, I found some of the SS flanged finish washers online.
Tom Hemphill
Postby Tom Hemphill » Tue Mar 27, 2018 5:50 pm
Thank you Bigbear and PatSea for introducing me to something I had never heard of: flanged finish washers. They look like a good alternative to traditional finish washers.
