1976 SPORT 13: Length of Remote Control Cable
Posted: Tue Apr 24, 2018 10:22 am
by vautour
I just bought a 1976 Boston Whaler Sport 13 here in The Netherlands. I decided to re-power with a new Yamaha F20 four-stroke. Now the dealer asks me which length I need for throttle and shift cables
I googled. Is it correct I need 8-foot shift and throttle cables?
Thanks for your advice.
Kind regards from The Netherlands
Re: 1976 SPORT 13: Length of Remote Control Cable
Posted: Tue Apr 24, 2018 6:09 pm
I believe the usual rigging method for mechanical remote control cables will have them run back from the starboard gunwale along the gunwale toward the transom, make a 90-degree turn to run parallel to the transom, and then make a 270-degree loop to go to the engine. I suggest you measure that path yourself and see what length you find.
Posted: Wed Apr 25, 2018 3:35 am
by vautour
Thx, I would measure it myself but boat is in storage and cannot be entered at present. Hence my question.
Posted: Wed Apr 25, 2018 10:08 am
I should have mentioned: I am assuming you have side-mount controls and they will be on the starboard gunwale.
