93 Yamaha 50 Tilt assembly -Ball Bearings and Spings
cjd
Postby cjd » Sat Jun 16, 2018 7:36 am
93 Whaler turning in to a bit of a project.
Hoping for some help here. Rebuilding trim and tilt. I could not get the caps off of the assembly to save my life, so a friend took it to his shop. Non Boating. The techs pulled all three caps (2 trim 1 tilt).
Here is the problem.
On the larger middle tilt cylinder, when I opened ups the bag, the top slipped and hit the bottom of the boat. A mini explosion of springs and ball bearings occurred. I cannot find any diagrams that show me how to properly reassemble the spring and bearings. I believe I got them all.
Any help here? Anyone have a diagram? I have no idea how to position the bearings and springs back in to the housing. Every diagram I see assumes the housing has the bearings and springs installed. I am assuming they are some kind of valve set up to allow fluid to flow. I am so close to finishing what I thought was a simple project.
Would love to get this thing in the water for fathers day.
Re: 93 Yamaha 50 Tilt assembly -Ball Bearings and Spings
Postby Phil T » Sat Jun 16, 2018 10:21 am
Is this what you are looking for? I had to guess on model #.
https://www.simyamaha.com/category_s/12913.htm?year=14&model=715&part-category=53
If it is not, I would call Andy at SIM Yamaha for help on the diagrams. He might not be able to send you one, but may be able to describe it. Worth a shot.
https://www.simyamaha.com/Contact_Us_s/14.htm
