1994 vs 1997 Outrage 17' trailer specs
Will a 1994 17' Outrage fit on a trailer built for a 17' 1997 Outrage II? I need to replace my trailer and no one seems to have the specs for a 1994, including Whaler themselves.
Re: 1994 vs 1997 Outrage 17' trailer specs
Dave-
Welcome.
Generally speaking, yes. You need to verify the axle rating since the Outrage 17 II hull weighs 680 lbs more and carries more fuel. Need to factor added fuel capacity, 32 gallons versus 56 gallons, increased beam as well.
I just replaced my trailer for my Outrage 17 I. I added keel rollers myself.
http://www.loadrite.com/spec-sheet-generation/?sheet_id=2841&sheet_model=18280096VT
Welcome.
What kind of specs are you looking for. If you have the old trailer, the new trailer company should be able to set the trailer up perfectly from that.
