1994 DAUNTLESS 15 Finding New Rail Kit
Nick
Postby Nick » Sun Nov 01, 2020 11:40 am
[This post has been removed from MARKETPLACE because the post initiated a discussion. Do not post to MARKETPLACE with the intention of seeking information or soliciting informative replies. The post has been moved to REPAIR and MODIFICATIONS for discussion--Moderator]
I recently picked up a project dauntless 15 that’s missing the rail. The hardware mount locations are there, so I know it had one. I see the stantions and misc hardware are still available.
Is finding a new rail kit unheard of?
I’d certainly buy used if I could find one.
--Nick
Re: 1994 DAUNTLESS 15 Finding New Rail Kit
Postby Phil T » Sun Nov 01, 2020 6:23 pm
There is no off-the-shelf kit available.
If you are in New England, you can contact CMI in Weymouth MA and they can fabricate new rails.
https://www.cmimarineproducts.com/
If you are in the Mid-Atlantic states, Martin Marine Design can fabricate it for you.
http://www.martinmarinedesign.com
If not in either geographic region, list what state you are in and maybe a member can recommend a good fabricator.
Nick
Postby Nick » Sun Nov 01, 2020 7:36 pm
Thanks, Phil. I’m in Minnesota.
What models and what model years would have the same rail system?
{Would a rail kit be] only [for] 15 footers?
I’d also consider purchasing a salvage unit just for the rails and extra parts.
- Nick
- 1994 Dauntless 15
Postby Jefecinco » Mon Nov 02, 2020 9:10 am
Unless you want to "restore" your Dauntless you may find a locally fabricated rail to be more satisfactory for everyday use. Many anglers find the OEM rails higher than they like. If you want to install a bow mounted trolling motor in the future the OEM rails could make that process more difficult and expensive. Since the original rail mounting is visible a local fabricator would have a relatively easier time building a rail that suits your needs.
