250 OUTRAGE Garboard Drain Plug
borlaw
Postby borlaw » Fri Jan 15, 2021 2:19 pm
How often should I remove garboard drain plug on a 250 OUTRAGE?
[Should the garboard drain plug on a 250 OUTRAGE be removed during] regular Spring maintenance?
Re: 250 OUTRAGE Garboard Drain Plug
Postby Phil T » Sat Jan 16, 2021 10:46 am
If the boat is stored out of the water, plugs should be removed.
If stored in a rack or at a marina I would not remove it or trust them with it.
