Desert Tan Deck Sealant
CarolinaWhalin'
Postby CarolinaWhalin' » Sun Sep 25, 2022 2:36 pm
Q1: what brand and color of sealant is a close match to Desert Tan and is recommended and readily available to caulk seams on the cockpit deck of an OUTRAGE 18?
Re: Desert Tan Deck Sealant
Postby Phil T » Sun Sep 25, 2022 6:12 pm
I used OSI Quad #450 last year—a perfect match:
[Update 2024: The link that was appended to this post now points to a different product; the link has been removed. See below for an updated link.]
pagraham
Postby pagraham » Thu Jan 04, 2024 1:09 pm
Hey Phil--In your response [above from 2024], you recommend OSI 450 [as being a good color match to Desert Tan, but] the link [that was in that post and has now been deleted] takes you to [a vendor's page selling a different product,] OSI 405.
I learned OSI uses numbers for colors, and there are color charts.
Please confirm the [OSI] color number that you know is a good match [for Desert Tan].
--Paul
Postby Phil T » Thu Jan 04, 2024 7:32 pm
Sorry, bad link.
No one on Amazon is selling # 450 now (1/4/24)
Here is a new link.
https://www.menards.com/main/paint/caulks-sealants/silicone-caulk/osi-reg-quad-reg-window-door-siding-sealant-12-pack/1636981/p-1444432314256-c-7935.htm
Honestly many owners go with Boat Life's Life Caulk in white as it ages to tan. Just takes a few years.
This is what you should use for all your screws and sealant needs.
https://www.wholesalemarine.com/life-calk-polysulfied-sealant-35165.html
