2006 Outrage 240
aftrhours
2006 Outrage 240
Postby aftrhours » Mon Dec 05, 2016 5:28 pm
I am looking at a very good deal on a [2006 240] Outrage with a single [VERADO] 250. My boating will be dinner cruises, tooling around offshore and some casual fishing. I doubt that I will carry more that 75-gallons fuel. When I say offshore, I mean a mile or two, and that is about it.
Will the 250-HP engine suitable for my boating style?
Thanks--Tom
Re: 2006 Outrage 240
Postby Jefecinco » Mon Dec 05, 2016 7:02 pm
I assume [the acronym you used] is an abbreviation for Verado. A 250-HP Verado should be sufficient power for the activities you listed. I once had a MUCH heavier 240 SeaRay with 260-HP stern drive and the power was just fine for that boat.
Postby jimh » Sat Dec 10, 2016 4:56 pm
By the way, offshore (to me) means you can't see the shore anymore.
msirof2001
Postby msirof2001 » Tue Dec 13, 2016 2:06 pm
"[V]ery good deal" is probably the significant factor as your usage description doesn't align to the Outrage 240 as well as it does align to the Vantage line. Outrage 240 is for offshore, more hard-core fishing. It will be great for when the conditions become rough in that 1-2 miles offshore you'll be taking it. And if you decide later that you want to take it farther than originally anticipated, you'll have the capability. However, the boat is less a creature-comfort configuration and more for hard-core fishing. Vantage still has the deep-V-offshore-capable hull but with a more ergonomic, family-friendly cockpit design. I liken this to buying a Steiner Commander-V with Compass binoculars when all you use them for is viewing concert performances. Great for those couple of times when needing their full capabilities but heavy to hold-up at concerts and drag them around. Make sure the configuration works for most of the time, not the exception. However, if you don't want to spend a lot, and this literally falls to you from out of the sky at a really great deal (and it is in good condition), you always have resale value if you decide to get something else.
Buoy
Postby Buoy » Thu Dec 15, 2016 10:46 pm
Boston Whaler has the minimum power listed at 225-HP, and so the 250 Verado will be sufficient power and likely produce a top speed of approximately 42-MPH.
LOA: 23' 9" (7.23 m)
Beam: 8' 6" (2.59 m)
Draft (boat only): 18" (.45 m)
Weight (dry, no engine): 4400 lbs (1995 kg)
Maximum Weight: 3500 lbs (1587 kg)
Swamped Capacity: 9680 lbs (4390 kg)
Persons Capacity: 12
Maximum HP: 350 hp (260 kw)
Minimum HP: 225 hp (167 kw)
Maximum Engine Weight: 1060 lbs (480 kg)
Transom Height: 25" d / 30" s (.63 m / .76 m)
Fuel Capacity: 150 gal (567 L)
Bridge Clearance: 6' 6" (1.98 m)
with T-Top: 8' 10" (2.69 m)
Tell us more about it.
