2004 150 SPORT Propeller Refit
mragu
Postby mragu » Sun Apr 23, 2017 7:42 pm
Just picked up a 2004 150 Sport Whaler for my friend's son. It has a Mercury 60-HP three-cylinder two-stroke-power-cycle engine. The aluminum propeller that came with [the 2004 150 SPORT] had limited markings on it--no diameter or pitch--[just] we 10 S 1400.
What propeller pitch and diameter is recommended?
Should [my friend] stick with an aluminum propeller?
Is it worth it to go to a stainless steel propeller?
Thanks, Mike
Re: 2004 150 SPORT Propeller Refit
Postby Phil T » Mon Apr 24, 2017 9:01 am
According to Boston Whaler, the 2004 150 Sport came with the option of a Mercury 60 two-stroke or a Mercury 60 FOURSTROKE. For the two-stroke motor, the factory shipped a 10-3/8 x 13 Mercury Black Max aluminum propellor.
The common advice to Boston Whaler owners is to select a stainless steel propeller for best overall performance. The adage of aluminum propellers preventing damage to the motor if struck is spurious.
Propeller sizing is a challenge. It is not universal across brands or even manufacturers. The same size propeller in a Black Max will not perform the same as a Stiletto or Solas or XXX propeller due to the differences in blade design.
I would definitely go with stainless, just not sure of make, model or size.
mragu
Postby mragu » Tue Apr 25, 2017 6:41 pm
Phil--Thanks for the info.--- Mike
mn car guy
Postby mn car guy » Fri Apr 28, 2017 10:52 pm
What kind of performance are you getting with the current prop? Rpm at Wot? How long to plane? Can you see the A/V plate when you are on plane?
Mr T
Postby Mr T » Fri May 05, 2017 8:38 pm
While I do agree that the "conventional wisdom" of using an aluminum propellor to avoid lower unit damage is without merit, I would like to add that in the case of a 60 hp motor on a 15 ft hull, I do not believe a stainless steel propeller is warranted.
It's my experience that aluminum will do just fine on this configuration.
