SURVEY: 15-footer Owners Who Install Jack Plate
jccraveswaves
Postby jccraveswaves » Tue Jun 13, 2017 1:35 pm
[Asks for respondents to indicate if they are using] a jack plate on a 15-footer.
mdono
Re: SURVEY: 15-footer Owners Who Install Jack Plate
Postby mdono » Wed Jun 14, 2017 8:46 pm
I am currently running a 1986 15-footer with a 1998 Mercury 90-HP outboard engine. I have an Atlas Micro Jack rated for 115-HP that works well. The pump [is] contained within the confines of the jack plate. I wish [the jack plate pump] had two speeds for raising and lowering.
El Rollo
Postby El Rollo » Mon Jun 19, 2017 9:57 pm
[My boat has a jack plate made by] Bob's Machine Shop, the five-inch manual version. I'm very satisfied.
russellbailey
Postby russellbailey » Wed Jun 28, 2017 11:04 am
We have an MJ-5 on ours - it is setup in the 5" offset negative 6-degree orientation.
http://www.bobsmachine.com/Convertable- ... 205000.htm
After we identified the height that worked well for us, I removed the adjusting screws for better clearance with a swim platform.
