Dauntless 13 Re-power
Macbones
Postby Macbones » Sat Dec 09, 2017 1:24 pm
Hello. [I am] considering a re-power for my 1997 DAUNTLESS13 that currently has an Evinrude 40-HP. Newer outboard engines seem quite a bit heavier [and] 210-lbs to 240-lbs.
The E-TEC 30 weighs 170-lbs. Would the E-TEC 30 be a good choice?
Re: Dauntless 13 Re-power
Postby jimh » Sat Dec 09, 2017 4:29 pm
I don't think the E-TEC 30 is a good choice for the DAUNTLESS 13. It is mostly used with tiller steering. A 20-inch-shaft remote steering model weighs 181-lbs. I would seriously consider moving to the larger 40 to 60-HP engines, at 240-lbs.
RichS
Postby RichS » Sat Dec 09, 2017 11:42 pm
I had a [1997] Dauntless with a HONDA 40-HP for eight years. It would do about 32-MPH when lightly loaded, and [the DAUNTLESS and HONDA were] a great combination. Even better would be the HONDA 50-HP, which I think is the same weight, about 214-lbs, and also the maximum horsepower rating for the boat. I think [the HONDA 50] may be one of the lightest four-stroke-power-cycle 50-HP engines.
Macbones
Postby Macbones » Sat Jan 20, 2018 11:51 am
A Yamaha 50 is about 243[-lbs]; the 40 [is] 215[-lbs]. Perhaps I should set a 40[-lbs] plate on top of the existing 1998 40-HP and see how she sits.
[Note: we don't use the octothorpe symbol for any units or dimensions. Use lbs for pounds.--jimh]
