Effect of Propeller Diameter and Material Change
Jelawman
Postby Jelawman » Wed Mar 21, 2018 3:36 pm
Would going to a stainless steel 14.25 x 19 propeller from an aluminum a 14.5 x 19 propeller [produce a] noticeable difference?
Or not?
I have an opportunity to get the stainless [propeller for] very cheap. Thanks for the help.
Re: Effect of Propeller Diameter and Material Change
Postby jimh » Wed Mar 21, 2018 7:24 pm
What is the horsepower of the engine?
How many blades does each propeller have?
Postby Phil T » Wed Mar 21, 2018 8:13 pm
Yes, or No. Depends.
Prop performance is not universal to size and material. Blade design is unique to each model of prop.
The size being close does not have any relationship to performance.
What is the model and year of the boat?
What is the year and model of engine?
What is the WOT range, gear ratio?
What is the mounting height of the engine (see FAQ)
What is the performance (WOT) for your current prop?
Ridge Runner
Postby Ridge Runner » Fri Mar 23, 2018 7:01 am
The material of the propeller accounts for a very small amount of the propeller's performance. The majority effect comes from the propeller's geometry; compare: pitch, diameter, number of blades, rake, and cupping.
Member since 2005
Postby jimh » Fri Mar 23, 2018 10:33 am
Propeller material affects performance. See
Propeller Basics: Part 2: Propeller Materials
http://continuouswave.com/whaler/reference/prop2.html
Until the OP reveal the horsepower of the engine, it will impossible to form a cogent reply to his question.
If ALL other aspects of a propeller remained constant, an increase in propeller diameter would suggest an increase in propeller load on the engine turning the propeller shaft.
Please note: The originator of this thread has never returned to participate or acknowledge the discussion. This is an annoying behavior. If you want to initiate a discussion, please have be courteous and come back to read the comments.
