I have a 1965 Classic 16 with a 2000 NISSAN 50-HP Model NS50D2 two-stroke-power-cycle engine using a stock propeller. The engine weighs about 180-lbs. I just had it out on the water the other day and [the boat] ran perfectly - but I think there is some room for improvement in speed and economy. This is a great little set up and I'd like to get the most out of it.
[The boat speed] topped out at about 30-31 MPH, engine speed was 5200-5300 RPM trimmed out. Maximum RPM per the manual is 5150 to 5850 RPM. I'd like to get to about 5500.
The engine seems to be mounted a little low. I'm thinking I could raise it about an inch or two up using current mounting holes. On top of that, I want to upgrade to a stainless steel propeller or a better propeller that would provide more performance.
Gear Reduction per the manual is 13 : 24
Does anyone have a suggestion on the best propeller to use for this set up?
Would a jack plate (manual) improve performance any?
Classic 16 Performance and Propeller Advice
Re: Classic 16 Whaler Prop / Performance Advice
M -
Keep in remember, you have a motor that is 1/2 the rated maximum.
If you want to improve performance, I would raise the engine 2 bolt holes and retest. Typically, raising the engine 1 hole raises the WOT rpm by 150-200 since there is less lower unit in the water. You have room to go before hitting WOT.
This is a DIY and can be done on a trailer.
A jackplate will not generally help increase speed and adds weight.
I understand I have half the rated horsepower on the boat, but I think the benefits of having a light engine on this non-smirked hull are severely overlooked. This boat handles great and feels well balanced. I can cruise at 25-MPH all day, which honestly, unless the sea is flat calm, is plenty fast. At this point I'm looking to maximize handling and efficiency while reducing draft.
I can only raise the motor one hole up using existing mounting bolts; see the picture. I will do that this weekend. Do you need a engine lift? Or do you use the trailer jack to raise and lower the engine mounting height?
[Give] suggestions on a propeller.
Thanks.
Thanks.
I would raise the engine using trailer jack.
Would want to read the results and see what WOT rpm's you can get before changing props.
Peter has a good recommendation here: http://continuouswave.com/ubb/Forum4/HTML/005862.html
Re: Classic 16 Performance and Propeller Advice
I will raise the engine this weekend and hopefully get out one of these days to test.
[Give me an] idea of the fuel economy of this set up. I've never gotten around to testing, but I figure I must get be getting [over] 6-MPG cruising at 4200-RPM and boat speed of 21 to 22 MPH.
Usually a classic two-stroke-power-cycle outboard engine will have a brake specific fuel consumption of about 0.55-lbs/HP/hour.
For a 50-HP engine running one hour, that is 50 x 0.55 = 27.5-lbs/hour fuel consumption. For gasoline that has a density of 6.25-lbs/gallon, that will be a fuel flow rate of 4.4-GPH.
If your boat were getting 6-MPG, then the boat speed necessary to get that economy from a burn rate of 4.4-GPH would be about 26.4-MPH.
I was able to raise the motor this weekend. Take a look at the pictures and let me know if this seems right. It was raised just about 1.5 inches. I was not able to use the top mounting holes, so I will either have to fill them up and drill new ones, or test using the outboard clamps. The bottom of the bracket is through bolted.
- outboard3.JPG (80.12 KiB) Viewed 12127 times
- Outboard 4.JPG (60.79 KiB) Viewed 12127 times
Make sure you have those holes sealed of preventing water from entering your transom.
After testing replace that aluminum prop with a stainless one using any prop selector found on the internet. Higher RPM = lower pitch.
Update - I was finally able to test the boat with the new raised engine height. I was able to hit 5500 RPM trimmed out. Before motor was raised I would bounce around 5200 RPM. Boat speed surprisingly did not change much, I still topped out at 31 MPH. I put 40 miles on the boat through some pretty rough weather at times and she handled fantastic.
Now I'm thinking about changing the OEM prop to a good stainless steel prop. Any recommendations?
With a WOT of 5850, gear ratio of 1.85:1, 5% slip and a target speed of 35, the prop calculator suggests a 13" pitch prop.
A respected member on this site, Peter, recommends the Stilleto's Triad II in 10.5 x 13 for your engine.
A whaler prop guru also recommends the same prop. See 4th before last post in this thread:
http://continuouswave.com/ubb/Forum4/HTML/006024.html
Dan's Discount Prop's is a respected vendor by many in the whaler community. See item #8023130013 here:
https://dansdiscountprops.com/BuyNow/stiletto.cfm#triad2
Thanks for the help - unfortunately Stiletto has been out of business since 2013 or so, and the website you linked does not have any stock
I know a 15 Sport owner who runs a 2005 Nissan 50. He is running a 11-1/8 x 13 Solas New Saturn. Part number 5331-111-13. He is very happy with its performance.
