1969 Minot 16 Re-power
Hornet
Postby Hornet » Tue Jul 30, 2019 9:55 pm
I plan to re-power a 1969 MINOT 16. This MINOT 16 has its original Chrysler 85-HP engine.
I have looked at old posts.
I plan to buy a Yamaha F70.
Is there a better choice [for a new engine other than a Yamaha F70] for this older lightweight [MINOT 16] hull?
This MINOT 16 will be used mostly for fishing in a bay and on a good day I may go four miles in the Gulf.
Re: 1969 Minot 16 Re-power
Postby jimh » Wed Jul 31, 2019 8:15 am
You should prefer the newer Yamaha F70A engine over the older F70 model.
The F70A weighs about 262-lbs with a propeller and has a 1.0-liter displacement. Yamaha has been able to reduce the engine weight on this model to a rather amazing figure.
An alternative choice might be an E-TEC 75 or 90-HP, but they weigh 320-lbs. The E-TEC 75 or 90 have 1.3-liter displacement, and they would be a more powerful engine than the Yamaha F70A.
Give serious consideration to the dealer you will buy from. All engines need some after-sale support, and a strong dealer, someone who has been selling an engine brand for a long time, with excellent service facilities will be a factor in your decision on what engine and from whom to buy.
Hornet
Postby Hornet » Wed Jul 31, 2019 8:38 am
Do you think the E-TEC engine would be too heavy?
Are the E-TEC engines as reliable as a four stroke?
I am not sure of the weight of the original motor.
Postby biggiefl » Wed Jul 31, 2019 11:15 am
If you are happy with the performance of the Chrysler, the F70 ill be plenty. That hull can handle the weight of an e-tec and more, but, again, if the 85 satisfies your needs.
Hornet
Postby Hornet » Wed Jul 31, 2019 4:29 pm
Thanks for your response, the original 85 did a ok on performance but it's time for an new motor. But this boat has been sitting for many years and the local mechanics said they can't repair the motor.
Postby jimh » Thu Aug 01, 2019 9:52 am
The legacy E-TEC three-cylinder engine has been chosen to re-power many 16/17-foot Boston Whaler hulls. Usually the 90-HP model is used, but the 75-HP model is less expensive and only has a few less ponies. I’d say the “90” is probably an 87-HP and the “75” is probably a 79-HP.
These E-TEC engines were very popular, but makers of four-stroke-power-cycle engines worked hard on reducing their weight, and there are now alternative choices.
There are two-stroke-power-cycle outboard engines that are over 40-years-old and have over 4,000-hours of runtime. There is nothing intrinsic in a four-stroke engine that assures long service life.
whalerron
Postby whalerron » Fri Jan 31, 2020 10:16 pm
I re-powered a 1969 Minot with a 2001 Johnson 90-HP two-stroke-power-cycle outboard engine that weighed about 320-lbs. The engine was a match made in heaven for the MINOT 16.
