I have a [2001--always use FOUR DIGITS for years, please] Montauk 17 with a Mercury ProXS 115-HP engine and the LASER II 20-pitch propeller that came with the original engine [which apparently was not the Mercury ProXS 115-HP engine].
The [MONTAUK 17] runs great, but at full-throttle the Mercury ProXS 115-HP engine only accelerates to around 5,200-RPM. and the boat speed is 41-MPH. The Mercury ProXS 115-HP engine is rated for 6,400-RPM. The ProXS 115 will push larger and heavier boats 10-MPH faster with propellers of the same size as the LASER II 20-pitch, and those engines accelerate to 6,000 to 6,200-RPM--where the Mercury ProXS 115 is designed to run.
Q1: what is causing the MONTAUK 17 and the Mercury ProXS 115 to run slower?
Q2: is a different propeller needed in place of the LASER II 20-pitch?
On the newer model 170 MONTAUK with the Mercury 115-HP FOURSTROKE an ENERTIA 18-pitch propeller is standard, and the top boat speed is 46-MPH.
Q2: what is holding back [the boat speed for my MONTAUK 17 with Mercury ProXS 115]?
2001 Montauk 17 115-HP
Re: 2001 Montauk 17 115-HP
I assume a classic 17' and not a 170. Something is wrong. Have you broken in the new engine yet? Some do not perform correctly until a certain hour mark is reached to protect it. If so then follow Jim's suggestion and check linkage because you would need to drop to a 13" pitch to fetch 6400-RPM, and that is not right.
Is the engine mounted all the way down?
Or, do you have the engine mounting height elevated?
The [Mercury ProXS 115-HP engine] is mounted [here the mounting height was described with an ordinal number--please describe engine mounting height in terms of the number of units of "holes" or 0.75-inches the engine is mounted above the lowest possible height, which in this case I believe you meant to be a mounting of one-hole-up from lowest position]---the same as the old 90-HP engine was mounted.
As of April 4, 2021, the [Mercury ProXS 115-HP engine] has 67 hours.
I tried a Turning Point 13.25 x 17-pitch propeller. The Turning Point 13.25 x 17-pitch propeller really improved acceleration [compared to a Laser II 20-pitch propeller], but the engine only accelerated [to a maximum engine speed of 5380-RPM] up 100-RPM from 5280-RPM with [the Laser II 20-pitch propeller] and [the boat speed declined] about 2-MPH. It [not sure which propeller is now "it" perhaps still means the Turning Point 13.25 x 17-pitch propeller] caused the boat to porpoise terribly. Even with 500-lbs in the [bow] of the boat or even with just me in [the boat], the [boat] still porpoised excessively at maximum boat speed.
I changed propellers on April 3, 2021, to use a Turning Point MAC-3 13.25 x 19-pitch. To my amazement for the first time [the engine] managed to [accelerate at full throttle to] 5,750-RPM and boat speed was either 45-MPH or about 46-MPH. [This boat speed is] the best I have managed to get out of [the Mercury ProXS 115-HP engine] so far.
The hull bottom could be cleaned, repainted, or buffed out. I think [those changes would cause boat speed to improve] 2-MPH based on [something] I have read.
[The boat under discussion here] is a Montauk 17--not the 170.
I checked the [engine] throttle linkage. As best I can tell [the engine throttle is] opening all the way. I will inspect it before I go out again.
I honestly don't know what kind of performance I should expect from this boat and engine combination. I just want [the boat performance] to be as good as it can be--particularly considering the amount of money I have spend on re-powering.
April 3 and April 4, 2021 have produced the best performance since [the Mercury 115-HP engine] was installed during the last week of August 2020.
[The engine speed of] 5740 to 5750-RPM, [the boat speed of] 45 to 46-MPH, and the fuel efficiency are really impressive.
Propeller performance is not all about size. You need to take into account the make and the model of the propeller.
From experience, a Montauk 17 with a 115-HP engine running light and mounted three-holes-up should be able to reach 49-MPH.
What model year is the Mercury 115 Pro XS?
The early versions had a gear ratio of 2.38:1 and the current motor has 2.07:1 gears. Need accurate information to use a propeller calculator.
If it is a current model with 2.07:1 gears
If we enter in key information: WOT rpm (6300)*, slip (5%), gear ratio (2.07)* and target speed (49), we get a recommended pitch of 18.
(* Per Mercury website)
If 2.38 gears it means a 20 pitch is recommended.
As for make and model of propeller, I would recommend a stainless steel prop. You don't specify model of Turning Point.
As for make and model I would start with a Mercury Enertia and PowerTech SCD.
I would not just throw props at it but discuss propeller selection with someone who knows Boston Whaler boats and propellers. Call either Dan's or Ken at Propgods.
http://www.dansdiscountprops.com
http://www.propgods.com
Note - Good props are very expensive: $400 to $800. Don't go cheap. That will be like buying a Ferrari and installing the tires from a Radio Flyer cart.
The 115-HP engine was made in May 2020. The gear ratio is 2.07:1
I have tested three propellers. I ran each propeller on multiple trips. The boat loading was fairly constant with two adults, one cooler with 20-lbs ice, fuel tank at 10 to 12-gallons, one Jack Russell terrier, and one anchor. Below are the test data. The engine speed and boat speed are for full throttle.
TEST 1
Propeller = Mercury LASER II 14 x 20-pitch
RPM = 5,280
MPH = 44
TEST 2
Propeller = Turning Point MACH 3 Express 13.25 x 17
RPM = 5,400 to 5,420
MPH = 43.5
There was repeated up-down oscillation of the bow (porpoising)
TEST 3
Propeller = Turning Point MACH 3 Express 13.25 x 19
RPM = 5,750 to 5,800
MPH = 46 to 47
There was no bow oscillation (porpoising)
TEST 1
RPM = 5,280
MPH = 44
TEST 2
MPH = 43.5
TEST 3
MPH = 46 to 47
It is clear you are not on the right path.
Also, the engine should be mounted two- or three-holes up, top bolt in the third or fourth hole down from the top. This is why you are porpoising.
I recommend you go back and read my prior post.
I am willing to try anything. I am by no means an expert. The 2001 MONTAUK 17 is really the first boat I have ever owned. I just want [the performance of the MONTAUK 17 with the new 115-HP engine] to be as good as can be.
I would reach out to Ken or Dan.
I will call Prop Gods and see if they can steer me in the right direction.
Please renew this thread when you get another propeller and have more test data to present.
