NAUSET 16 Yamaha 90-HP
Posted: Tue Sep 05, 2023 3:41 pm
by Blackduck
[An earlier discussion about this boat focused on engine mounting height and possible changes and benefits.]
I did not change the engine mounting height for the Yamaha 90-HP two-stroke-power-cycle engine on my NAUSET 16 boat [as was discussed in the prior thread], and I left the engine as it had been mounted [in the lowest possible position and] using the blind mounting bolts.
With a Yamaha aluminum propeller [of unknown number of blades and] 17-pitch, the NAUSET 16 boat is very responsive. The Yamaha 90-HP engine accelerates at full throttle to 5,500-RPM, producing a boat speed of 42-MPH speed over ground by GPS.
I feel that less than 1-MPH speed would be gained if the engine were raised two-holes higher.
I feel that replacing the current aluminum propeller with a better propeller might add a bit more boat speed--but not very much.
Advice I got from Jim and Phil [who both recommended against buying and installing a jack plate] was good advice, and I saved a lot of time and money [by not buying and installing a jack plate].
The 50-year-old NAUSET 16 is shown in Figures 1, 2, and 3.
Fig. 1. A NAUSET 16 with all,original wooden components, now reparied.
Fig. 2 The dock were the photographs were taken.
Fig. 3. A 50-year-old NAUSET 16.
The original wooden components were taken apart, stripped, repaired, and put back together. To replace the original wood with new wooden parts would have been a lot less work, but the plywood available today is just not suited or intended for marine use.
Re: NAUSET 16 Yamaha 90-HP
Posted: Tue Sep 05, 2023 11:41 pm
Getting a boat speed of 42-MPH sounds quite good to me for an old 16-footer and an aluminum propeller.
The boat looks very nice, too. Where is that dock?
Posted: Wed Sep 06, 2023 8:16 am
After reading your post and a good night sleep, I think you should upgrade the propeller to the Yamaha painted stainless steel model in 13 x 17.
It will not need to be replaced if you hit a buoy or debris.
The boat will perform better at all speeds.
Just be happy you don't need an Enertia propeller for $860--No foolin'.
Posted: Wed Sep 06, 2023 8:35 am
Again, Phil and I agree: an aluminum propeller has about zero tolerance for a blade striking anything, while a steel propeller will tolerate a blade strike with some sort of softer material without any deformation of the steel.
If you do any boating in shallow water, there will be some sort of encounter between a propeller blade and something in the water at some point in your future.
Posted: Wed Sep 06, 2023 10:37 am
by Blackduck
Fig. 4. The dock seen from shore.
Dock is located on Winnapaug Pond in Westerly, Rhode Island. The pond is saltwater and tidal. The location is the west end, north shore. I built the dock 15 years ago. It is 100-feet long, as was needed to get some water depth. The photo from my front yard.
