LiFePO Batteries for Marine Use
Postby jimh » Sat Mar 26, 2016 11:34 am
As a replacement for the traditional lead-acid storage battery, there are many new battery technologies being developed and brought to market. Several of these are based on Lithium. Of the Lithium storage battery technologies, batteries are now available using a Lithium-Iron-Phosphate chemistry that have the favorable characteristics of higher energy storage per weight, while avoiding the problem of self-heating that is seen in other Lithium batteries. This technology has been around for a while, so it is not the absolute latest, cutting-edge, untested invention; if fact, some refer to it already as old-school.
A good article on Wikipedia explains the chemistry of the LiFePO or LiFePO4 battery. It discusses the advantages and disadvantages of LiFePO4 batteries compared to other chemistries. Inherent safety of the battery is often mentioned. This battery chemistry is not prone to the self-heating and thermal runaway problems seen in other chemistries using Lithium. Another interesting facet: the LiFePO4 material is a natural mineral compound; iron is, of course, abundant and low cost, and non-toxic.
The LiFePO battery would seem to be a possible choice for replacement of lead-acid batteries in marine applications. I made an attempt by searching to locate a suitable LiFePO battery that could be used to replace my Group-24 AGM battery. I could not find an equivalently rated battery in that size with LiFePO chemistry. I found some 40-Ah-rated LiFePO4 12-Volt batteries selling for about $235. Their peak current for short duration was rated 400-Amperes. That should start most outboard engines. I also found some more expensive LiFePO4 marine batteries that were $580 to $700, but again rated only to 400 to 500-Amperes maximum short duration current.
The general marketing of these more expensive LiFePO4 batteries as competitors to less expensive lead-acid batteries is with emphasis on the these advantages:
--perhaps ten times greater number of charge-discharge cycles possible (3,000 compared to 300);
--a significant reduction in weight (30-lbs compared to 80-lbs);
--a greater useable energy storage capacity for similar size (about 2:1);
--almost no drop in output voltage during discharge cycle;
--ability to tolerate very deep discharge without harm.
I am curious if any readers have experience with LiFePO batteries or may have purchased one for use in their boat. While their cost is greater than premium lead-acid AGM batteries, they appear to have several advantages that might be particularly useful in certain marine applications. For example, an electric trolling motor running from an LiFePO4 battery may be a very good application. A bow-mounted trolling motor with the battery close by would benefit from the significant weight reduction, the greater energy storage, and the ability to tolerate deep discharge-recharge cycling.
Re: LiFePO Batteries for Marine Use
Postby jimh » Sat Mar 26, 2016 11:55 am
The size and weight of a battery as a function of its energy storage are measured by volumetric density and gravimetric density, perhaps two terms not familiar to all boaters. Wikipeda compares the LiFePO4 battery to lead-acid batteries on these parameters:
Gravimetric energy density (higher is better)
Lead-acid = 30 to 40 W-h/kg
LiFePO4 = 90 to 130 W-h/kg
Volumetric energy density (higher is better)
Lead-acid = 60 to 75 W-h/ dm³
LiFePO4 = 220 to 330 W-h/dm³
( A dm³ is more familiarly called a 1-liter volume; W-h is 1-Watt for 1-hour.)
fno
Postby fno » Mon Mar 28, 2016 10:20 pm
Lithium based batteries catch fire all the time and some burn with the intensity of magnesium. Not on my boat.
Postby jimh » Tue Mar 29, 2016 9:11 am
Frank--you must have missed an important point of my first article about LiFePO4 batteries. Please re-read the first article in the thread. You are not making a proper distinction between various battery chemistries involving Lithium. The Lithium-Iron-Phosphate chemistry is not prone self-heating and to thermal runaway. It is much safer than other Lithium battery chemistries.
Postby jimh » Fri Apr 08, 2016 1:04 pm
I came across a recently published article on LiFePO4 batteries. The article refers to them often with the acronym LFP. The article is quite detailed and offers a wealth of information on LiFePO4 batteries. See
https://marinehowto.com/lifepo4-batteries-on-boats/
The article includes a link to a demonstration of attempts to cause a LiFePO4 battery to explode or ignite in flames. The test is quite aggressive in its methods. First, a handgun fires several rounds into the battery case while it sits in some dry grasses. There is lot of smoke as acid is released but no flames. Next a dead short is placed across a fully-charged cell. Again, some smoke but no explosion, no flames. The battery supplies 1,800-Amperes into the short circuit.
Test three involves lighting a fire in a large barrel with some wood and accelerants. Once the fire is burning strongly, a LiFePO4 cell is tossed into the barrel. There is no explosion. Later the fire is extinguished and we see the charred case of the battery in the barrel. The fourth test puts the LiFePO4 battery into an oven chamber, and heats it to 85°C or 185°F. There is no sign of any damage; the battery terminal voltage is measured and is still at full-chage.
Next the battery is placed in some testing apparatus which drops it onto a steel plate from about a 1-meter height several times. The battery appears to absorb this shock testing without damage. After that a crush-test is conducted using a calibrated machine. The cell appears to survive this treatment, too. A following test uses large spikes to penetrate the battery case. This test causes some smoke and probably releases some acid.
The final test appears to be connecting a battery to an enormous 500-Ampere resistive load. The battery supplies current to the load for quite a while, then its terminal voltage is measured. The voltage remains at almost the initial full-charge voltage.
The demonstration is completely narrated in a Chinese language and all graphics on screen are in a Chinese font, so most viewers in the USA won't be able to understand what is being said or written, but the pictures tell most of the story. Watch the presentation at
https://www.youtube.com/watch?v=aQs7L5L ... e=youtu.be
If anyone has any evidence to support the claim that LiFePO4 batteries "catch fire all the time" please comment and give a cite to your source.
Postby jimh » Wed Apr 13, 2016 10:20 am
Just when you thought it was safe to invest in LiFePO4 batteries, also sometimes referred to as LFP batteries, here comes some new technology start-up with something even better. That is "even better" in terms of better energy density and lower cost.
A company called BioSolar is promoting a new battery technology which will use their patent-pending technology, which they refer to with the descriptor "Super Cathode." The claimed advantages for the Super Cathode battery method are impressive. We compare with the LiFePO4 technology, which, until this new method appeared, looked to be quite an improvement itself compared to conventional lead-acid storage batteries.
ENERGY DENSITY
LiFePO4 = 72-Watt-hour / kilogram
SuperCathode = 459-Watt-hour / kilogram
COSTS
LiFePO4 = $403 / kW-h
SuperCathode = $54 (an estimate)
The SuperCathode battery has six times the energy density and its cost is only one-seventh of the LiFePO4 battery. Where do I get one? I don't think you can get one. The BioSolar company is just announcing their invention, and I don't believe they have any batteries for sale, nor are they likely to pursue actual manufacturing. I think they would like some big battery manufacturing companies to license their technology and bring to market a real battery that uses it. Read more at
http://www.biosolar.com/super_battery.php
If the BioSolar SuperCathode battery does make it to mass production and has the energy density and energy cost parameters that are stated by BioSolar, the founders of BioSolar should be very substantially compensated financially for their discovery, and the lead-acid storage battery market would quickly disintegrate.
Hoosier
Postby Hoosier » Wed Apr 13, 2016 8:04 pm
[The BioSolar SuperCathode Lithium Ion battery if ever made] could be great for trolling motor and house batteries. It'd be nice to be able to anchor out for a couple of days without having to run a generator.
knothead
Postby knothead » Fri Apr 15, 2016 8:09 pm
I recently read an article on the website "Watts Up With That" that discusses the proposed [SuperCathode Lithium Ion] battery and BioSolar. I scrolled through the comments, some of which were written by people far smarter than me (kind of like this website), and concluded that the battery may be "a pie in the sky" deal to help pump up the stock price of BioSolar, which has fallen substantially.
I wish and hope that this battery technology would work, as it would mean a great deal to the future of stored electricity.
Hope it warms up up there.
regards---knothead
Postby jimh » Sat Apr 16, 2016 8:33 am
I browsed the "WhatsUpWithThat" website, and found it interesting. As I mentioned in my article, there are no SuperCathode batteries from BioSolar and they do not seem likely to ever make one.
There are real LiFePO4 batteries available to purchase, and they do seem to have advantages compared to existing batteries.
Hoosier
Postby Hoosier » Sun Aug 05, 2018 5:33 pm
Here's an update: I just finished a boat trip to the North Channel with the BWGLCC ( see http://continuouswave.com/forum/viewtopic.php?f=8&t=3674) and at the overnight stop in Killarney, Ontario my house and starboard starting battery failed. Since we were at a marina I had connected the battery to shore power with a (kinda) smart battery maintainer. In the morning the entire house electrical system was dead and the charger's "Bad Battery" light was on.
One of the members of the group had a RELION BR 50 LiFePO4 12-Volt battery that he was willing to lend me. We pulled the bad lead acid battery, cleaned up some crappy wiring, and installed the RELION BR50 battery. I then proceeded to complete the 2018 BWGLCC North Channel cruise without a hiccup. The battery supported the whole house electrical load for two nights at anchorage and started the starboard 2010 Yamaha F150 immediately every time.
After returning to Michigan I stopped in at the RELION dealer in Lansing and discussed the RELION batteries. He had checked with the manufacturer and they do not recommend the BR50 as a starting battery. They have a new dual purpose 50-series battery coming out later this year that will fill both the starting and deep cycle roles.
Postby Jefecinco » Mon Aug 06, 2018 8:50 am
Dave,
I call that a very positive endorsement. Perhaps a RELION would be a good replacement for the old lead acid battery on our old Sport 13. The 13 gets little use and weight aft is undesirable. If the self discharge rate is equal, similar, or better than a typical AGM that would be pretty irresistible.
I'll have to look for a dealer in the Gulf Shores area. We moved here this Spring. We're on the GC-IWW sometimes called Portage Creek.
Postby Jefecinco » Tue Aug 07, 2018 10:00 am
The closest Relion dealer to Gulf Shores, AL is located in Orange, TX. I guess I'll stick with AGM batteries for now.
porthole
Postby porthole » Wed Aug 22, 2018 12:06 am
I have been doing some research on LiFEPO4 batteries for RV use.
BattleBorn and LiFeBlue are two popular suppliers.
    --Neither company recommend use as starting batteries.
    --The batteries are impressive both in performance and price.
    --Typical price for a 100amp hour battery is $900+
The batteries are typically compared to conventional flooded lead-acid or FLA, AGM, or gel-electrolyte batteries for discharge limits. For example, a 100-Ampere-hour conventional battery is recommended to be discharged no more than 50%, essentially a 50-Ah rating.
LiFEPO4 batteries can be discharged 80 to 100%, so an effective capacity of 80 to 100 AH.
LiFEPO4 claim of 3000 to 5000 discharge-recharge cycles is very impressive.
The above mentioned suppliers build batteries with internal battery monitoring systems or BMS, which offer protection to the battery against several parameters. LiFeBlue also includes built in Bluetooth monitoring capability.
Although I am planning on a LiFEPO4 system of 400 to 600-Ah for our RV, I would not consider the batteries for my boats: too pricey for the gain, unless I planned on spending days on the open water with no power source.
Duane
1999 Outrage 21
1999 Yamaha SW Series II 200
porthole
Postby porthole » Wed Aug 22, 2018 12:16 am
That website linked above is no longer operating, but the article--I think it is the same article--can now be found here:
[Thank you; I updated the original article to have the new link.--jimh]
Duane
1999 Outrage 21
Didien
Postby Didien » Mon Nov 19, 2018 3:34 am
To bring this thread back around, here are my comments.
A LiFePO4 battery has some real advantages. If the cost were a close call, then I would choose them over lead-acid. However, as people have pointed out, they are (at the moment) several times more expensive, and I suspect that in reality, they won't really last all that much longer than lead-acid batteries. In marine applications, one of the oft-overlooked advantages of LiFePO4 is the absence of hydrogen gas generation (as with lead-acid), meaning they're suitably for use in small sealed spaces, which could be of particular interest to small power boats and RIBs.
My advice: go for a good quality, maintenance-free sealed lead-acid battery. For example, get two Lifeline GPL31-T batteries 105-Ah each. They are genuinely what I would use if it were my boat to replace your current setup. Get a decent charger, and low-voltage disconnects where necessary to ensure you don't unduly bugger them up, then enjoy the boat. If you really want to take the extra step to get better reliability and longer life of the battery system, increase the capacity a bit; just put some more 31-T's in parallel)/ The more shallow the discharge of a lead-acid battery the longer it will last.
It's worth saying that many go for an even cheaper option of going for Trojan T-105 (6-Volt) flooded lead-acid batteries. From reports (on here) they're pretty rock solid and reasonably cheap to replace when it comes round to it. After all, all batteries are consumables and WILL need replacing at some point. These will need maintenance--electrolyte top-up.
porthole
Postby porthole » Mon Nov 19, 2018 12:51 pm
Didien wrote:A LiFePO4 battery has some real advantages. If the cost were a close call, then I would choose them over lead-acid. However, as people have pointed out, they are (at the moment) several times more expensive, and I suspect that in reality, they won't really last all that much longer than lead-acid batteries. In marine applications, one of the oft-overlooked advantages of LiFePO4 is the absence of hydrogen gas generation (as with lead-acid), meaning they're suitably for use in small sealed spaces, which could be of particular interest to small power boats and RIBs.
LiFEPO4's are advertised as 10-15 years service or 3000-5000 cycles. Pricing for a typical 12 volt 100 Amp hour battery is about $950. Their advantage or use is not practical for our power boat applications.
Where they shine is with renewable energy and or inverter applications. When used that way and taking the 3000-5000 cycle life expectancy and the up to 100% SOD (state of discharge) the LiFEPO4's come out less expensive for a given amount of stored energy. Probably half the cost, along with 3-5 times the life expectancy and at less then half the weight (29 pounds).
Along with that, the 3 main suppliers all say the batteries are not suited for engine starting applications.
Didien wrote:It's worth saying that many go for an even cheaper option of going for Trojan T-105 (6-Volt) flooded lead-acid batteries. From reports (on here) they're pretty rock solid and reasonably cheap to replace when it comes round to it. After all, all batteries are consumables and WILL need replacing at some point. These will need maintenance--electrolyte top-up.
On smaller boats I would stick with 12 volt batteries and AGM's or Gels.
6 volt just adds complexity and expense.
My small boats all had some type of sealed lead acid battery, mostly AGM's (all 12 volt)
My big boats (as well as the many I crewed on) all had flooded lead acid batteries. (all 12 volts, but some boats had 24 or 36 volt systems)
My RV's, I've tried them all, FLA's, sealed, 6 volts and now LiFEPO4's.
I'm using 6 100 amp hour rated LiFEPO4s with a 3KW hybrid inverter and it will soon be supplemented with about 1800 watts of SOLAR.
For that application the new technology shines bright.
I went from 4 AGM's at (approx) 100 AH each which at 50% discharge rating gives me 200 useable amps at 300 pounds.
6 LiFEPO4s at 100 AH at a nominal 80% discharge rate gets me 480 useable amps (up to 600) at 174 pounds and 3-5 times the life expectancy.
Duane
1999 Outrage 21
Don SSDD
Postby Don SSDD » Tue Nov 20, 2018 9:31 am
ASPIN KEMP & ASSOCIATES is a company in Prince Edward Island that does large marine hybrid power, windmill, and solar storage systems. They are working with several different types of lithium batteries and say there are many batteries in the experimental stages for commercial and consumer. Their marine hybrid power is for tugs, plus they were involved in a new build hybrid offshore oil drill rig power system. Significant fuels savings with marine hybrid and loads of torque all the time. They produce significant electricity off the anchor chain system on the drill rig which is then stored in batteries and they have large banks of capacitors as part of the system.
From what I have seen them working on and the progress in battery technology over the last 10 years--just look at the change in your mobile telephone battery in the last 10 years--I wouldn't be surprised to see battery technology improve so we can be using automobiles and outboards powered by electricity within the next 10 years. My lead acid batteries may last that long, thus not much advantage buying this new stuff now, but wait until it needs replacing and we'll have some really nice new stuff available.
Maybe we'll have a small 25-HP gasoline engine (running once in a while at full or optimum rpm) to charge our super light storage batteries and an electric motor running our propeller. Replacing our current 150-HP outboard that only uses peak power a small percentage of the time and is running and burning fuel all the time.
The key to all this is a better battery that has a large capacity, discharges slowly, charges fast, and is lightweight. I think that will happen sooner than we think, but I've been wrong before.
http://www.aka-group.com/
Don
Nova Scotia
Postby jimh » Sun Nov 25, 2018 9:29 am
Regarding re-chargeable storage batteries: I bumped into a knowledgeable fellow recently who worked for a major automobile manufacturer on their in-production electric vehicle. He said that the OEM supplier of the battery had engineered it for a service life of 25-years. Of course, the car maker did not offer a 25-year warranty on the battery. But knowing that the OEM supplier felt his product was sufficiently well made to last 25-years gave me more confidence about buying one of the vehicles.
Other than the requirement for light weight for marine propulsion use, just about all the desired characteristics for a re-chargeable storage battery are the same across all applications. Use in marine propulsion will be a small market. Use in energy storage for general utility and for vehicle propulsion will drive battery development.
Don SSDD
Postby Don SSDD » Sun Nov 25, 2018 9:45 am
The bulk of autos sold with hybrid technology and the one that has been around the longest is the Toyota Prius. I believe when they came out they had a 7 year warranty on the batteries and I think they have outlasted that by say double. I would also hope that the battery made today for the Prius will be lasting longer than the one made when they originally came out about 20 years ago.
Nova Scotia
Dutchman
Postby Dutchman » Tue Nov 27, 2018 10:51 am
It will be the future. This boat has been doing it successfully for a while and at speeds over 40-MPH.
Postby jimh » Tue Nov 27, 2018 1:02 pm
Does "it" mean: to cost $299,000 for a 22-foot boat?
I hope "it" is not the future of boating. I will have to drop out at those prices or downsize to a 2.2-footer.
porthole
Postby porthole » Tue Nov 27, 2018 5:32 pm
You're good to go Jim, those prices on the website are Canadian dollars. So it will only be $225,000 for you.
Duane
1999 Outrage 21
