Adding Image to Post
Introduction to the forum software and its feature. You can use this for test postings. This is not a boating forum
Postby jimh » Sat Aug 19, 2017 10:37 am
There are two methods to add an image to a post:
--point to the URL of the image that is available, or
--upload the image as an attachment to the post.
Images that have already been uploaded in one post can be re-used in other posts by pointing to the URL of the image in the original post where it was uploaded. Images are included by use of the IMG tag. Wrap the URL for the image with the [ I M G ] and the [ / I M G] tags. For example, if an image is hosted at the URL http://foo.bar/images/image.jpeg, then to include the image as an in-line image in a post you would wrap the URL with the IMG tags: [ I M G ] http://foo.bar/images/image.jpeg [ / I M G]. Here I added spaces to prevent the tags from working.
To upload an image as an attachment to a post, use the tab with the Menu Icon in the post composition window at the bottom of the window, then select the ATTACHMENTS sub-menu, then upload the image from your terminal to the forum host.
To upload a file from your local terminal to be hosted by the forum, click on the ADD FILES button (seen above at the lower left of the screen grab)
LIMITATIONS ON IMAGE FILES
In order to upload an image, the file format is limited to certain types, the total file size is limited, and the width of the image is limited.
LIMIT ON FILE FORMAT: the supported file types are .gif, .jpg or .jpeg, and .png. The website does not support uploading of image files in the .tif or .tiff format.
LIMIT ON FILE SIZE: The total file size is limited to 256-kB. This is an enormously generous file limit, and there is hardly any image that needs to be more than about 50-kB.
LIMIT ON IMAGE DIMENSIONS: The image width cannot exceed 900-pixels in order to not disrupt the layout of the forum.
Once the image has been attached to the posting, the image will automatically be shown at the end of the post as an attachment. If it is desired to control the location of the image in the post, the image must be selected to be an INLINE image. Then the code for the image can be moved to the appropriate position in the post as the author desires. It is STRONGLY urged that images be made to be in-line, that they be numbered in sequence as they will appear with the first being Fig. 1, the next Fig. 2. and so on, and that there be explanatory captions that describe the image in detail.
IMAGE ORIENTATION: In-line images will be show in their original orientation. This is a function of HTML in-line images. Images for inclusion in-line in HTML must be properly oriented. Please to not shoot images with your camera held vertically for portrait format. That you own a camera that can take images files of hundreds of megabytes does not mean you get to post them here. Such massive images are not appropriate for illustration purposes in a text-based forum.
Don SSDD
Re: How to post picture
Postby Don SSDD » Mon May 21, 2018 5:53 pm
How do I post a picture?
Nova Scotia
Postby jimh » Mon May 21, 2018 7:39 pm
Advice on how to use the forum software is given the Introduction forum and is given in the forum FAQ (not the boating) FAQ.
I moved your inquiry to this thread. See answer above.
Don SSDD
Re: Adding Image to Post
Postby Don SSDD » Sat Jun 02, 2018 3:16 pm
Test to see if I'm doing this correctly.
I have a Picturetrail hosting pics.
[IMG}http://pic20.picturetrail.com/VOL164/2040090/3952594/413914181.jpg{IMG]
The problem is the first right bracket is wrong. And at the end the left bracket is wrong --jimh
Nova Scotia
