OK gentlemen, I have 14 boxes that should more than cover those showing interest.
In the pic I only have 1 screw installed, the other 3 are inside the box with the gasket.
When you receive the box, determine how you will mount on the hull (portrait or landscape) and install the gasket so that it is on the bottom of the box. The gasket may need to be trimmed or stretched to fully seat in the recessed lip. I found it best to cover the hole in the hull where the wires come through and drill a hole in the back and use silicon on the back to make a watertight seal on the hull. For the wires going to the sternlight, I also drilled a hole in the bottom of the box so the wires exit and go to the stern light. Using a blob of silicon will seal around the wires and also offer strain relief to your install.
Email me at mackeyboat (at) gmail (dot) com and I can provide a Venmo or Paypal address for payment and then I can get these shipped out to you. If paying by check, email me and I can provide the mailing address. Shipments are to the lower 48 states and will be USPS with tracking.
