I have just finished applying the primer coat [of paint on a hull being restored]. The primer coat has a pebbly finish.
Q: Should I sand [the primer coat surface to be] smoother before applying the topcoat?
I read--maybe on the directions of the Wet Edge topcoat paint--that you should sand the primer smooth with 220 grit before applying the topcoat.
Please offer advice.
Paint Application: Sanding primer coat before applying topcoat
Re: Paint Application: Sanding primer coat before applying topcoat
Did you apply the primer with a spray gun? Could the result be "orange peel" in appearance? I would want a perfectly smooth final primer coat before applying finish coats. If sanding the primer smooth removes too much of it and you need to reapply it consider changes to your application method. If you are using a roller the nap of the roller can make a significant difference in the outcome. The thickness of the application may also contribute regardless of the method used. Environmental conditions can also affect paint application outcomes. Recommend you carefully read the instructions, if any, that came with your paint and do further online research on the subject before proceeding.
There are some experienced painters on this site and I'm sure they will provide some expertise.
I'm assuming you primed with an epoxy primer as they are usually the best for building a great base that adheres to your topcoat. On my projects, I sand the primer with anywhere from 180 grit to 320 grit depending on how the surface looks and the level of finish I'm looking for. There are many factors that play into this:
- type and brand of primer
- type and brand of topcoat
- how the surface is sanded, that is
- by machine
- by hand
- by wet sanding
- by dry sanding
I applied a top coat of paint with a foam roller to a primer coat without sanding the primer coat smooth. Predictably, the top coat paint ended up being bumpy as well. The top coat paint goes on very thinly. I recommend getting the primer coat as smooth as possible with a 220-grit and then 320-grit sandpaper.
