FS: 1984 OUTRAGE 18 with 2020 Yamaha F150 $32,900 in Texas
danekline
Postby danekline » Mon Oct 19, 2026 12:24 pm
FOR SALE: 1984 OUTRAGE 18 notched transom with a 2020 Yamaha F150 in Houston, Texas, for $32,9000
CONTACT: Phone: (281) 948-66fivethree
Email: dane.m.kline@gmail.com
Fig. 1. Outrage 18
Fig. 2. Yamaha F150
Fig. 3. Boat trailer
HULL
The boat has undergone an extensive restoration. The hull is dry and solid:
  • full fiberglass refinish
  • new 62-gallon aluminum fuel tank with new sender and fuel gauge
  • fuel tank installed on neoprene strips rather than foamed in, providing a drainage gap for water removal
  • all new fuel hoses
  • new fuel-water separator
  • new plywood and fiberglass decking beneath the fuel tank cavity cover.
ELECTRICAL
  • complete boat rewire
  • individual components properly fused and grounded
  • two new batteries
  • Blue Sea battery switch allowing either battery to start the engine while permitting isolation of the starting battery
  • NOCO Genius GEN5X2 onboard battery charger
  • Humminbird HELIX 7 MSI G3
  • JL Audio MediaMaster MM55 stereo
  • two JL Audio M6 6.5-inch marine speakers
INTERIOR
  • teak cleaned, brightened, sanded and freshly oiled
  • Reversible Pilot Seat completely restored with new upholstery
  • RPS raised approximately 4-inches to accommodate a 70-quart cooler and provide additional storage
ENGINE
  • 2020 Yamaha F150 four-stroke-power-cycle
  • approximately 275 hours
  • runs excellent
  • serviced May 2026 including, engine oil, gear oil,spark plugs, thermostat, and water pump
TRAILER
  • original single-axle trailer
  • refurbished
  • new LED lights and wiring
  • new winch and strap
  • new tires
  • wheel bearings recently repacked with grease
  • new tongue with 2-inch coupler
The boat runs excellently and does not porpoise. This is a well-sorted classic OUTRAGE 18 with extensive mechanical, electrical, structural and cosmetic restoration completed, along with modern Yamaha engine.
Restoration photographs are available, including photographs of the hull, fuel tank installation, decking and other work performed.
