1969 13' custom - Rebuilt and ready
Postby Phil T » Tue Aug 09, 2016 2:59 pm
I am posting for my friend Bob. This is NOT my boat.
1969 Boston Whaler 13
2011 ETEC 25 -perfect running motor – New fuel pump last weekend.
Top speed ~ 26 mph with 2 adults. Uses VERY little fuel and is 100% dependable.
2016 Load Rite bunk trailer, 12” tires , with front rolling jack. Approximate 50 miles on trailer since new!
ALL work completed within the last 3 months:
Garmin ECHO Map GPS Chartplotter/Fishfinder and Transducer installed 7/27/16
Binnacle Shift/Control Box
New shift cables
New Compass
New Custom Mahogany Interior, 5 coats of varnish
NEW Floatation FOAM under deck, bulkhead and in transom , ALL old foam was removed in these areas
New DECK – ½ plywood, fit, tabbed in with fiberglass then complete surface was fiber glassed and new Non-Skid paint was applied.
New Teleflex Safety Connect steering system
New Steering cable
New 20 degree Bezel for Steering Wheel
New 13.5” S/S Steering wheel with Suicide knob
New transom raised 5” and new foam
New wiring- ALL
New- Paint, Topside, Non-skid , Outside Fighting Lady Yellow and New bottom Paint, entire hull was stripped prior to all!
New Fire Extinguisher
New Life Jackets
New Expandable Paddle
New dock fenders/bumpers
New Norman pin in bow
New 6 gallon Fuel Tank
New 3.5 Gallon back up fuel tank
(Both fuel tanks fit under seat)
New Battery
New Battery Cables
New Cupholder
New knife/plyers holder on console
New rod holder – holds 3 fishing rods and plyers
New RAACOR Water Separator
New Fuel Lines
All New hardware- every screw was replaced with new stainless steel screws and finish wahsers
New Ignition switch
New bow lines, and dock lines
New hull Logos
4 - New Maritime Skiff Grab Handles
New Boston Whaler Seat Cushion
This is a dry boat, llightweight, and 100% re-done. Needs nothing.
Project and Finished Photos: http://s527.photobucket.com/user/CascoBayOutrage/library/Annie4s%201968%20Boston%20Whaler%2013?sort=2&page=1
Boat is located in Southern Maine.
Asking $9300 or BRO.
Contact Bob @ CARPEB@mmc.org
