You guys always know everything. ABYC regulation E-13.3.5 states that a GFCI (Ground Fault Circuit Interrupter) is required for 110-VAC outlets in the head and gallery. Why doesn't a circuit breaker in the circuit breaker panel cover this? Do you need both? I've already got the circuit breaker installed.
Thanks.
JimP
GFCI 110 Outlet and Circuit Breaker
- Resize of El Buc 051316_20160513 62..JPG (93.26 KiB) Viewed 6058 times
Re: GFCI 110 outlet and circuit breaker?
It would be if your panel had a GFCI circuit breaker.
Looks like you have all standard magnetic overload circuit breakers.
In simple terms, regular breakers protect against an overload of the hot wire.
GFCI breakers (or receptacles) protect against current leakage. The current going from the source to the appliance and back to the source should be equal (equal between the hot and neutral).
If not there is a 'leak' and a GFCI would trip if installed.
Here is a Blue Seas version of a GFCI breaker you could add to your panel.
https://www.bluesea.com/products/3106100/A-Series_ELCI_Main_Circuit_Breaker_-_Double_Pole_120V_AC_30A
Duane
2016 World Cat 230DC
1997 Outrage 18, Yamaha 125
1983 15 SS, Honda 50
1980 42 Post
1983 34 Luhrs 340 SF
Duane
1980 42 Post
With your panel it would be easier and less expensive to just add a GFCI outlet at the beginning of the outlet run.
More info
https://www.bluesea.com/support/articles/1473/Blue_Sea_Systems_Offers_Solutions_for_Mounting_ELCI_Breakers_to_Comply_With_ABYC_July_2010_Requirements
https://www.bluesea.com/support/articles/1381/AC_Ground_Faults_the_Boater_and_ABYC-Understanding_Equipment_Leakage_Circuit_Interrupters_%5BELCIs%5D_and_Ground_Fault_Circuit_Interrupters_%5BGFCIs%5D_to_make_your_boat_safer.
More info
Duane
1980 42 Post
Duane
1980 42 Post
Porthole -
Thanks. Good info.
JimP
Thanks. Good info.
JimP
Re: GFCI 110 Outlet and Circuit Breaker
Porthole -
Was traveling when I replied before.
Got a chance to get back to the boat yesterday/today. Replaced the boxes with bigger boxes to fit the GFCI outlets in the head and galley. Had to do some "minor" surgery on the bulkheads to get the new boxes to fit. But the GFCIs are in and working.
JimP
JimP
