For sale: an 1979 Boston Whaler 15 Sport with four-stroke 2014 Yamaha F70 engine with 77 hours.
Motor maintained at 20 hours and winterized at dealer, with fresh zincs and fuel filter yearly. Always flushed at dock after use.
New bow cushion, 2 bench cushions in not great condition after bug spray. Have 4 aftermarket seats that can detach for bench cushions, using carpeted board to 'lock' them in. Custom ladder mount on the side, with stainless steel telescoping ladder. Have motor cover and boat cover.
Rub rail is coming off on left front, have replacement rub rail system.
Fresh bottom paint, and new drain tube installed. New helm and controls with new motor in 2014, and hull was dry inside.
Hull and mahogany wood show normal wear and tear for well used 1979 boat. Battery was moved from starboard to port.
Trailer had new tires, spare tire, fresh bearings, and 2'' coupler in 2013. In 2014 added new bunks, new fenders, and 3 Stolz 12'' poly keel rollers, for easy winching. New front leaf spring mounts in 2017.
Moved unexpectedly 18 months after repowering, and have not been using it much last 2 years, storing in garage.
$8300
joekrausejet at gmail.com
FS: Sport 15 with Yamaha F70 in Virginia, $8300
- Whaler (5) tiny.JPG (50.01 KiB) Viewed 3859 times
- Whaler (2) tiny.JPG (62.15 KiB) Viewed 3859 times
- Whaler (7) tiny.JPG (55 KiB) Viewed 3859 times
