Understanding ICON Pro Gauge Lighting
Postby jimh » Thu Aug 29, 2019 9:19 am
Control of the illumination of the ICON Pro RPM and Speedometer gauges is a complex system. The RPM gauge contains the settings; the path to them is:
NORMAL MODE --> Branch to EDIT MENU (by pushing MODE button for 1-second)
EDIT MENU --> Branch to DISPLAY MENU (by pushing MODE button for 1-second)
DISPLAY MENU:
Menu options:
---> LIGHTING
--> CONTRAST
---> # OF SCREENS
---> PAGE SETUP
---> DFLT SCREEN
---> AUTO SCROLL
---> SET UNITS
---> CLOCK
DETAILS OF LIGHTING MENU
------> CONTROL
|-----DEPENDENT (means dial and LCD lighting are ganged)
|-----INDEPENDENT (means dial and LCD lighting are not ganged)
If DEPENDENT is chosen, then options SYSTEM and SOURCE appear;
------> SOURCE
|-----INSTRUMENT (use UP/DN buttons to control lighting)
|-----BUS DATA (use bus data from ICON EST control to control lighting)
------> SYSTEM
|------use UP/DN buttons to control lighting (0 to 100) and save setting
but only works if SOURCE is set to INSTRUMENT
If INDEPENDENT is chosen, then SYSTEM disappears,
and four new menu options appear:
ADJUST LCD, LCD SOURCE, ADJUST DIAL, DIAL SRC
-----> LCD SOURCE
-----> DIAL SOURCE
-----> ADJUST LCD: use UP/DN buttons to control lighting (0 to 100)
and save setting but only works if LCD SOURCE is INSTRUMENT
-----> ADJUST DIAL: use UP/DN buttons to control lighting (0 to 100)
and save setting but only works if DIAL SRC is INSTRUMENT
For more details on the general layout of the EDIT menu and sub menus, see
Evinrude ICON Pro RPM Gauge User Interface
http://continuouswave.com/whaler/refere ... _Menu.html
