FS: 1966 Nauset w/1967 Kiekhaefer Mercury 1100 - $24,000 in NJ
Ourturn_1
Postby Ourturn_1 » Sun May 10, 2020 9:13 am
Complete Restoration of a vintage 1966 Boston Whaler Nauset
Powered by a fully restored 1967 Kiekhaefer Mercury 1100 (110 hp) outboard w/ Thunderbolt Ignition.
New Mahogany console with front seat
New mahogany pilot seat
Custom seat cushions with original "Boston Whaler" logo on pilot seat
Complete restoration of Paint
New Rub Rail
Moeller, 22 Gallon PL3 Topside Fuel Tank
Swim Platform w/ladder
All New Wiring
New Stainless Steel Railings
Custom Fabricated Travel Cover, Top Gun Fabric
2007 Karavan Galv Trailer w/ New Disc surge brakes & LED lights
Clear Title for boat
Engine Restoration:
 Mechanical restoration process.
All items are removed from the power head. The power head is dismantled and internal parts are inspected. Necessary parts are replaced or serviced as needed. The block will be serviced as necessary. Carburetors are dismantled and soaked for cleaning and reassembled with the use of new gaskets, seals, and needles & seats. New fuel hoses installed. Distributor over-hauled and re-wired, or serviced depending on what type of distributor and year of the motor. New spark plug wires, ends, and boots are installed. Fuel pumps are serviced with new gaskets, diaphragm's, and valves. Main wiring harness is repaired or replaced depending on its condition. New gaskets are used in re-assembly of the powerhead. The motor is then timed and tuned.  Lower unit is completely dismantled, all parts are checked and replaced if necessary. A complete re-seal kit is used in the re-assembly process.
Paint restoration process.
In order to refinish the motor properly a full dis-assembly is necessary. Power head is removed. Center section is then separated from the lower unit, swivel assembly. All parts are either sand-blasted or sanded clean, depending on condition of the parts.  All parts are primer coated in a urethane based two-part epoxy primer. The primer is then wet sanded flat and prepared for paint. All parts are base coated in the specified color, and then clear coated in a urethane top coat. The paint is then wet sanded and buffed for a perfect finish.
For sale $24,000.00
Located in Egg Harbor, New Jersey
Contact
ourturn_1@hotmail.com
609-513-3732
Re: FS: 1966 Nauset w/1967 Kiekhaefer Mercury 1100 - $24,000 in NJ
Postby Phil T » Mon May 11, 2020 2:06 pm
Please clarify.
The factory finish is gelcoat. Is the boat painted?
Ourturn_1
Postby Ourturn_1 » Mon May 11, 2020 4:24 pm
Yes, we chose to repaint to match original colors. We opened the deck to check the core, which we found in good condition.
Ourturn_1
Postby Ourturn_1 » Sun May 31, 2020 10:20 am
Price reduced to $22,000.00 or best offer.
Postby biggiefl » Mon Jun 01, 2020 10:31 am
Your stern lifting eyes are upside down...fyi.
Ourturn_1
Postby Ourturn_1 » Tue Jun 30, 2020 8:49 am
Good catch thanks! eyes corrected.
Splashed the boat, running great.
Ourturn_1
Postby Ourturn_1 » Mon Aug 03, 2020 8:28 am
looking for a good home for my Whaler, Price reduced to $21,000 or best offer
Ourturn_1
Postby Ourturn_1 » Tue Sep 29, 2020 11:31 am
Lowered sale price to $19,500 OBO
