Hello All,
I've ordered a new Igloo 94qt cooler for my Montauk. The old cooler was original and was very beat up. Just wondering if anyone knows if my old cooler cushion will fit on the new 94qt cooler. The plan is to get a new cushion from Anderson, but I would like to hold off for a season if I can.
As always, thank you.
Old Cooler Cushion, New Cooler
Beerspitnight
- Contact:
1989 MONTAUK 17
Re: Old Cooler Cushion, New Cooler
Yes, the cushion will fit.
The original cooler (86 qt) was the same width and length just shorter.
If you have rod back cushions, install the new cooler backwards. It allows the cooler to open without binding on the bottom of the rod cushion.
These are new rod and cooler cushions (Halls) with a new 94qt cooler on my 1987 Montauk.
- DeckBow.jpg (23.48 KiB) Viewed 3530 times
Beerspitnight
- Contact:
