SOLD For Sale 1984 Boston Whaler Montauk 17 SOLD
wcurling
Postby wcurling » Wed May 19, 2021 6:22 pm
Jim, thank you for allowing mw to post the Montauk For Sale.
For Sale: Unsinkable 1984 Boston Whaler Montauk 17 with 2002 Mercury 2 stroke 90 hp with less than 60 hours runtime. New floor installed. Internal foam was bone dry with no signs of moisture intrusion.
Console has been completely rebuilt with new wiring, redesigned interior shelving with carpet. Destroyer style steering wheel very comfortable to handle. Note there is a raised console shelf on stainless steel support columns Can be used for mounting electronics, storage box or whatever you wish to use it for.
Included is a Danforth compass, a Humminbird 565 Fishfinder, fire extinguisher and a boat anchor with chain and rode.
Dual battery system with dual battery switch. Batteries (1 year old), are mounted inside the console in order to move their weight forward causing the boat to set more level at rest and assisting in getting on step a little quicker. Heavy duty gauge wire was used from motor to batteries.
The forward storage/anchor locker hatch was re-hinged to the port side affording freer and easier access for anchor deployment and retrieval.
Binnacle was removed, cleaned, greased and a new shift cable installed.
All hardware and fitting on the boat were removed, cleaned, and re-bedded in marine bedding compound.
All teak and mahogany wood including the Reverse Pilot Seat was removed, cleaned, sanded and 5 coats of Pettit marine varnish applied.
Reverse Pilot Seat is positioned so it can be used seated or with the back moved forward as a modified leaning post. Really quite comfortable.
2002 Mercury 90 hp 2 stroke with a stainless-steel propeller and less that 60 hours runtime. Motor was purchased new and installed 2005. New water pump installed with new propeller hub kit. Engine has been tuned with new spark plugs and carburetors cleaned and rebuild by professional marine mechanic. Included are two new tilt and trim solenoids. New fuel hose and fuel/water separator filter. Boat anchor and telescoping boat hook are included.
1983 Cave trailer in excellent condition. New guide on poles, bunks and trailer lights including fender marker lights, with wiring harness. The tires are in great condition.
This boat is ready to put in the water and enjoy.
Asking 10,800
Photos are available for viewing at http://norfolk.craigslist.org/boa/d/portsmouth-for-sale-1984-boston-whaler/7324115504.html
Contact me at privadowcc@gmail.com with question concerns or even a reasonable offer.
Port Bow
BW3 Port Bow.jpg (180.25 KiB) Viewed 10490 times
Starboard Stern
BW4 Std stern.jpg (225.4 KiB) Viewed 10490 times
Console-RPS
BW14 Console--RPS.jpg (135.75 KiB) Viewed 10490 times
