Source for Anchor Locker Drain Replacement
hodgsonjl
Postby hodgsonjl » Sun Jun 13, 2021 7:11 am
[Give me a source for a replacement through-hull drain tube] for a 2004 190 Nantucket.
I believe the other [through-hull drains on the boat were made by] Perko.
I am having no luck [finding a replacement drain tube].
roundle1979
Re: Source for Anchor Locker Drain Replacement
Postby roundle1979 » Sun Jun 13, 2021 9:43 am
I ordered my 2004 Nantucket 190 through-hull fittings from Nauset Marine:
https://www.nausetmarine.com/
190-Nantucket-Thru-Hulls-Assembly-Parts-List-2004.pdf
(48.66 KiB) Downloaded 392 times
190-Nantucket-Thru-Hulls-Assembly-2004.pdf
(88.85 KiB) Downloaded 399 times
2004 Nantucket 190 w/ Mercury Optimax 135
hodgsonjl
Postby hodgsonjl » Mon Jun 14, 2021 8:33 am
Very helpful information. Thank you.
hodgsonjl
Postby hodgsonjl » Mon Jun 14, 2021 1:29 pm
Called Nauset Marine and they were admirable. Got what I needed and some other parts and they are being shipped today. Thanks for the recommendation.
Masbama
Postby Masbama » Tue Jun 15, 2021 8:22 am
I ordered mine through Sue Lodel but it is not yet installed.
If any of you would share your installation experiences; I would be most grateful.
Postby Phil T » Tue Jun 15, 2021 11:40 am
Mas -
My personal preference is to coat the entire tunnel in sealant or epoxy. Using a long art brush and a narrowed paint stir stick has worked for me. Once cured, dry fit tube. Apply painters tape around both flanges . Apply Boat Life on inside of flange and on the hull. Use a threaded rod with wide washers and nuts to ensure a good (tight but not too tight) fit. Remove rod and tape.
Masbama
Postby Masbama » Wed Jun 16, 2021 8:15 am
Thanks Phil!
