FS: 1972 SOURPUSS 13 for $9,500 in Michigan
youllsee
Postby youllsee » Tue Jul 09, 2024 1:42 pm
For-sale: a restored 1972 SOURPUSS 13 with 1982 Mercury 40-HP engine on a VANSON trailer for $9,500 in Ann Arbor, Michigan.
CONTACT: Terry Steller 734-216-5048
Fig. 1. The SOURPUSS 13 on fresh water.
Fig. 2. The SOURPUSS 13 on its trailer.
Fig. 3. Interior wood finish.
This restored 1972 SOURPUSS 13 is NOT a project boat by any means. It's ready to show or be used today. This hull has the smirked bow appearance. The engine splash well is the sink-style (as opposed to the older 13-footers with a deep and wide engine splash well). The Sourpuss has a full width console with center steering. The 1972 model year was the last for the SOURPUSS interior. The boat is beautiful; you won't be disappointed when you see it.
The boat has
  • teak wood interior refinished with premium Epifanes brand spar varnish
  • new Teleflex NFB steering with optional NFB feature (no feed back)
  • stainless steel destroyer-style wheel
  • re-chromed original bow chock with navigation lamp on custom baseplate;
  • new original style three-piece rub rail;
  • original blue interior in very nice condition, that has been sanded and polished to save the desirable blue gel coat; the non skid area still looks great though obviously not polished;
  • professionally painted with [Desert Tan] color, catalyzed urethane paint;
  • a transom riser (for long-shaft motor) professionally crafted laminated from 1/10-inch-layered mahogany
  • original optional high front railing
  • no water saturated foam anywhere, ever;
  • a new battery;
  • all wiring under the console is new and done with marine wire; a fuse panel is under the console.
The 1982 Mercury 40-HP two-stroke-power-cycle engine has a 20-inch or long shaft, and it runs and looks great.
Recent service items:
  • new water pump;
  • carburetors cleaned and tuned;
  • new 11-inch x 13-pitch propeller;
  • dry cylinder peak pressure readings of 149 and 150-PSI--very high.
The VANSON-brand trailer has 14-inch wheels and new submersible LED running lights. The trailer is a heavy-duty model, and it is in sound mechanical condition. A new paint job on the trailer is needed to bring it up to the cosmetic level of the boat. With the large wheels and tires, I wouldn’t hesitate to haul it anywhere.
