The [owner's] manual has [the well nuts] as part number 82138500.
ASIDE
[Moderator's note: comments made as a sidebar to the discussion of well nuts have been moved to their own thread. Also, for those not familiar with the term "well nuts" the intended meaning here is:
- Well nuts are also known as rubber well nuts, captive nuts, or expansion nuts, and are a type of fastener used to create a threaded connection in materials where a traditional threaded hole or nut might not be feasible or practical. They consist of a rubber or elastomeric body with a metal (usually brass) threaded insert embedded within. When a bolt is tightened into the well nut, the rubber compresses and expands, creating a secure and vibration-dampening hold.
