lhg
posted 03-13-2000 10:28 PM ET (US)
Peter: Glad to hear that you've been able to save your boat, but I almost hate to tell you that, in spite of the addition of foam into the hull voids, it is almost impossible to duplicate the Boston Whaler system of hull construction in a repair requiring structural foam, even on a Whaler. The key to the tremendous hull weight-to-strength ratio is the fact that the foam injection creates tremendous pressure against the STILL UNCURED fiberglass chopper gun mix forming the inner & outer hulls,(as the foam expands) and forms a permanent structural BOND with the still wet resins in the skins, both materials curing together as one. This bond, absent of any voids, is essential to the safety and strength of the Boston Whaler hull, since there are no other structural elements in the hull. As you may have noticed in the trailer discussion, Boston Whaler has always been concerned that nothing cause a foam delamination from the skin of the boat, which can destroy the boat's integrity. On of the most difficult procedures in the making of the Whaler hulls is containing the pressure exerted against the molds when the foam is added. The two parts of the hull are clamped together, with all sections being braced, to avoid hull distortion from the pressure of the expanding foam. I don't think there is any way that your repair shop will be able to re-create a true Whaler foamed hull, in spite of what they may tell you. |
