posted 04-26-2000 06:21 AM ET (US)
Bought a used 13' 1978 whaler recently with a 40hp Yamaha. The previous owner built a center console out of 1/2 " marine plywood stained and varnished to look like mahogany.I removed the swingback 2 person/seat/cooler cause it took up too much space crosswise. The 6 gallon tank and battery was just off to the side leaving very little room towards the stern. Decided to build a box to match the center console and position it lengthwise to create more space. The box will measure 17 w x 30 long x 16 high and will house a 12 gallon gas tank. The box will eventually have a swivel seat mounted to it.
Been going through the staining/epoxy/varnish procedure with the box and had settled on securing it to the deck with "L" brackets from the inside. Preferably stainless steel if I can find them or chrome plated brass. Definitely, stainless bolts and nuts through the box and stainless for the screws to the deck.
This is my first fiberglass boat. The wood box design and preparation has gone ok. The securing part of the job is what scares me. The gas tank will weigh about 90 lbs. full and the box should weigh 25 lbs.
What is the best procedure to follow regarding screwing and mounting large objects to the deck? Will a screw adhere to the foam filling once it penetrates the gelcoat and fiberglass?
I discovered that the center console has become loose and had to remove it altogether. The previous owner had secured it with 2" brass screws but the holes left by the screws had widened over time. I want to put the consle back and wnat to be sure that both the box and console will stay put for as long as possible.
help...suggestions...ideas!
Thanks to all.
