Topic: Choppy water tactics
Peter Dicker |
posted 08-10-2000 07:10 AM ET (US)
Well, I must apologise for not letting you know sooner that the little aussie whaler is back in action - better than ever. The shipwright did a first class job on the gelcoat repair and filled the hull with expanding polyurethane foam. I know it could never be as good as a real one but I love my aussie version anyway. I've added an upholstered bench seat behind the side console and a rear casting platform with built in livewell and underfloor fuel tank.The trolling motor is now up the front with a trailer plug socket in the front casting platform and the battery stored under. I will keep my promise of posting some photos shortly! In the mean time I have a question for the small boat(13')gurus. What is the best angle/speed combination for whaler style hulls when in choppy water? What about handling wakes from ski/wakeboard boats? This will probably open a can of worms but in any case I would appreciate your thoughts and tips on this. Regards, Peter.
dave_maggio
posted 08-10-2000 09:22 AM ET (US)
Peter,Nice to see you back...As far as your question goes, speed-slow, direction-quarter into them. Wakes are a constant obstacle to all small boats. The best option (if possible) is to boat on weekdays... -Dave |
triblet
posted 08-10-2000 10:27 AM ET (US)
Also, steer for the low spots. And with a cathedral hull (i.e., Montauk), if you land on one side first (as opposed to flat), the landing is softer. As you crest the swell, turn the wheel a quarter turn or so in the direction that would make you more parallel to the swell, as you land, a half turn the other direction, then a quarter turn the first direction. This doesn't make a big deviation in course, but does tip the boat to land one foot at a time.Go slow helps a lot. I've been out in stuff where I got airborne at idle. Not fun, not something I plan on, but it happens. I'd hate to be there in a Bayliner. Chuck Tribolet
