posted 10-20-2000 08:01 AM ET (US)
Whalerron,There should be numbers on the end of the hub under where the nut goes to hold the prop on. There may be a washer stuck to the hub that is blocking you from reading the numbers. Check and see if that is the situation.
You have a 1975 70 hp and the most likely prop on a Minot of that vintage was an OMC aluminum 13 1/4"diameter by 17" pitch. This size was 382764 and a later version was 391199. The 17" pitch for your engine is now a 14 X 17 but I am not sure of the part number.
To answer your real question, if there are no numbers anywhere on the propeller you would have to take it to a prop shop and they can check the pitch with a pitch block which is used in reconditioning.
Good luck, Dave
