  Cooler seat,transducer lacation
Author Topic:   Cooler seat,transducer lacation
Rick posted 11-23-2000 01:00 PM ET (US)   Profile for Rick   Send Email to Rick
Recently purchased a 1988 17 Montauk. I was told the cooler seat was 72 QT, but this is smaller than my current seat. What other sizes were offered. I am also installing a fish finder and wanted to know the best location for the transducer. Would like to mount it inside if the hull is solid in the sump area. Thanks for any help. Rick
dgp posted 11-23-2000 02:40 PM ET (US)     Profile for dgp  Send Email to dgp
Rick, my Montauk owners manual sez the following about x-ducers, "Transducers must be transom mounted. The transducer should be mounted in a clean flow of water. Check to make sure it is mounted away from spray strakes and so as not to interfere with trailering and trailer bunks. Most transducers will act as a small trim tab affecting hull trim. Transducers should be mounted on the port side, or on center to provide lift or have a neutral effect on the trim." Don
JT Dimmick posted 11-29-2000 11:37 AM ET (US)     Profile for JT Dimmick  Send Email to JT Dimmick
Check out my 5/22/00 posting and the replies in the performance forum. Mounting the transducer 8 inches from the centerline was the magic number for me. It is mounted on the starboard side as I have a kicker motor on the port. Good luck with your project. John
Rick posted 11-30-2000 12:11 PM ET (US)     Profile for Rick  Send Email to Rick
Thanks for the help. I found the earlier article and mounted 8" to port and it seems to work fine. Rick
lhg posted 11-30-2000 01:11 PM ET (US)     Profile for lhg
Rick, regarding the cooler size, your boat, and any Outrage with a standard sized console, came with the Igloo 86qt cooler.
In 1989, Igloo brought out their re-designed cooler line, and the 86 became a 94qt. But for some reason, BW switched to the smaller size, the 72qt. Never understood this, since I agree, the 72 is a bit narrow for two to sit. I'd go with a 94. I think Dave's Etc still makes the tan pleat matching cushions.
triblet posted 12-04-2000 09:09 AM ET (US)     Profile for triblet  Send Email to triblet
I'm not sure a 94 qt Igloo will fit flat
on the deck of a Montauk. My measurements
said it wouldn't. However, a 92 qt Gott,
which tapers in at the bottom, does fit
quite nicely. I adapted the seat pad for
some sort of Igloo (maybe a 94) to fit the
Gott by adding some snaps to the Gott and to
the straps on the pad.
Chuck Tribolet
LarrySherman posted 04-12-2001 01:10 PM ET (US)     Profile for LarrySherman  Send Email to LarrySherman
Does anyone know the correct cooler for a 25 Outrage with a super console. The 94 is too deep.
Thanks, Larry
lhg posted 04-12-2001 01:52 PM ET (US)     Profile for lhg
It's the 162 quart Igloo. Highly recommended. I have one on mine, and I liked the large size, and big seat so well, I put one in my 18 Outrage also.
LarrySherman posted 04-12-2001 02:54 PM ET (US)     Profile for LarrySherman  Send Email to LarrySherman
Thanks Larry. I'm going to West to look now. Happy Holidays!
Guts posted 02-16-2003 02:01 AM ET (US)     Profile for Guts  Send Email to Guts
Hu
