  OMC Oil Injection
Author Topic:   OMC Oil Injection
Ray posted 01-18-2001 10:28 PM ET (US)   Profile for Ray   Send Email to Ray
Purchased a 25' Revenge in August that has a 225hp Johnson 1986 model. I often wondered how reliable is oil injection on these engines? The oil tank is about 2 gallons and is in the back of the boat. It has a low level warning horn which works very well!!!!Is the performance of the injection system something that should be checked periodically or are these systems good for years?
Peter posted 01-18-2001 11:52 PM ET (US)     Profile for Peter  Send Email to Peter
Ray
You should always keep an eye on it. I think your tank is 1.8 gallons. I have the same size tank feeding a 1987 150 Johnson with a VRO2 pump. The tank's sending unit sends a low oil signal causing the horn to go off even when the tank's full so I disconnected it. Nevertheless, I watch the tank and can say that I go through about a gallon of oil every other fillup of the gas tank (about 35 gallons or more).
